Question about Raypak RP2100 DIGITAL POOL HEATER R265
Gvc code heater won't fire - Raypak RP2100 DIGITAL POOL HEATER R265
    Top Expert:
  • Raypak Master
  • 5,056 Answers
Gas valve closed check gas pressure
Posted on May 25, 2016
3 Suggested Answers
  • 54 Answers
SOURCE: My Rheem model P-M266A-EN-C is displaying this:
GVC means Gas Valve Closed. This fault can be caused by many different problems, or even a faulty gas valve. Here is a link to a PDF file that give a step by step troubleshooting chart. This may help put you on top of the actual problem. http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/raypak-r-series-oim.pdf
Posted on Sep 04, 2011
SOURCE: when I turn heater on
you need to check your thermostat for improper exposure to the sun or damage
Posted on May 21, 2011
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Wont always fire up
You probably have tankless water heater.
What brand water heater?
Gas or electric?
Is this new installation or old installation?
For Rheem tankless:
Copy following link: If you get no error code on remote control, then scroll down to 'no error code.'
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 11, 2012 | Water Heaters
What plug is recomended
what won't fire up?
Aug 01, 2012 | Heating & Cooling
Electrical - won't start. Hooked up fan to heater, smoke came out from under the hood, car won't start. Lights work, any key related electrical functions won't work
Your fan or heater likely shorted out and burned up, causing your one of the main fuses to blow due to the spike in current. You will need to determine what burnt up and replace it before replacing the fuse, or you may create a fire hazard or cause further equipment damage. Also double check any changes to wiring to make sure that everything is hooked up properly.
Nov 01, 2011 | 1991 Chevrolet Cavalier
My Rheem model P-M266A-EN-C is displaying this: GVC. The heater isn't working. What does this mean?
Sep 03, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
May 19, 2011 | Heating & Cooling
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak RP2100 DIGITAL POOL HEATER R265 Logo
313 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
