Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Side by Side Refrigerator Model # PSS26LSRD SS Freezer works but the refrigerator portion got so hot it melted the butter inside and spoiled everything. I took a hair dryer and melted the ice from the coils inside freezer conpartment seemed to help some. cleaned all compartments and vacumed off compressor,Refrigerator still will not cool below 40 degrees. Freezer seems to work fine. Not sure
  • ranburns May 28, 2011
    Can you send me diagrams or do I need to get them off the parts website.
    From what you know where would you begin?
  • GE Master
  • 11,800 Answers
The temperature setting in the fridge section of your refrigerator is generated by diverting a part of the cold air generated in the freezer. This is done with the help of a fan and is controlled with a thermistor. If the temperature doesn't drop low enough then either the fan is faulty and it will have to be replaced
http://www.appliancepartspros.com/part_details.aspx?part_id=3875639
or it's not properly commanded because either the thermistor is faulty
http://www.appliancepartspros.com/part_details.aspx?part_id=3185407
or the control board itself has failed and it continuously activates the defrost resistance
http://www.appliancepartspros.com/part_details.aspx?part_id=4436216
If you need diagrams you can find them here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5236940&diagram_id=23953624#d23953624
Posted on May 28, 2011
  • Azrael SRL May 28, 2011
    Take them from the site - open the last link, click on each diagram at a time, right click on them and select Save image option - it will be a gif file. Later you can print them. I would start by testing and replacing the thermistor, then the fan and only as a last resort i would access and test the board.
Hi, We have a ge refrigerator gsh25sgpa-ss. Water is leaking down the back of the inside of the freezer. We have replaced the filter and the water valve, any thoughts?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Vegges frozen...ice in ice maker melting GE model PSW 26 LSRD refrigerator
Checkthe freezer temperature. The proper freezer temperature should be around 5degrees. The warmer it is in the freezer, the more difficult it is to make ice.
Jan 27, 2011 | GE Profile PSW26P Stainless Steel Side by...
My ge profile refrigerator won't cool on the refrigerator portion and the freezer portion just melted. What is going on with the refrigerator and how do I get it to work? Is there a way to reset it? Also,...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Fridge was "hot" on the inside when I opened
Sounds like compressor out or relays on the compressor out. Is freezer side ok? If so you may have a defrost problem... http://www.houstongofarappliancerepair.com/Refrigerator.html
Dec 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
171 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
