Question about Watches
I just received a Welby German Mantle Clock with Westminster Chimes, that has belonged to my aunt for a long time. It worked perfectly at her house, but she became ill and the house sat empty for a year, so the clock was not wound or kept up. It has the key and 3 holes for winding. I don't know which is for winding the clock for time, which is for chimes, and what the 3rd is for. The one one the far left, facing the clock, seems to be wound and I don't want to wind it any tighter. The other two could be wound. I know it is not a valuable clock but it has sentimental value for me, and I love the chimes. There is a brass knob on the back at the top that says chimes, with arrows pointing each way, then SIE and in larger letters EIV7. The chimes are now sluggish, and I am afraid to try to adjust it for fear of throwing the whole mechanism off. Can anyone help me with this? I tried to look up information about this clock but only found sales sites. I would like to know how to take care of this clock, and how to wind it, set it, and any information about it you can give me. Does it need repair, or cleaning? I have always had good results from you all at Fixya. Thanks very much. Jeanne
  • 2 more comments
  • jkanady May 30, 2011
    Thanks for your suggestion. I am not sure about the graphite. My husband used to use it on locks and such to make the key easier to turn, but I am not sure about putting anything in the clock that might make it not work at all. I don't have a problem winding the the clock, except for the one that seems tightly wound. I don't know what that one is supposed to do. It seems to keep good time, but the chimes are slow and sluggish and that is what I am concerned about. I can get into the back. there is a large door on the back that opens with a ring handle. There are mechanisms in there that are obviously for adjustments, but I don't know how to adjust the clock. Since you say you don't know much about this clock I would rather hear from someone who does. Thank you for responding.
    Jeanne
    I am not sure about the advice I received, as he said he didn't know about my clock. I would rather hear from someone who does know this type of clock. It has a large door on the back, and inside are the works, and a couple of things look like they make adjustments, but I do not know what adjustments to make or even what they do. I am mostly concerned about the chimes being slow and what the different winding mechanisms do, especially the one on the left that cannot be wound. Thanks very much.
    Thank you for responding to my question. Yes, this is an 8 day clock and my aunt would wind all 3 holes every 8 days,without fail,as long as she was able. The clock has been striking every quarter hour and fully on the hour, so why is the left one not unwinding? My aunt would wind all three, but I cannot wind the left one as it is tight and never seems to need winding. Could it be overwound? It has been striking correctly, but it just very slow and hard to hear from another room. That was not the case at my aunt's house. You could hear it in every room. I wanted to know if there was any adjustment I could make, or does it need a clock repair person. The problem is there is only one that I know of on the MS Gulf Coast, since Katrina, and he is in another town about an hour away. Also, the key is not double ended and there is no eeky tweaky hole at "12" :o) Thanks for your help.
  • jkanady Jun 02, 2011
    Yes. The response was what I thought, that it needs cleaning, although it looks very clean in the back, the mechanisms and all. I was glad to know the numbers and letters, SEI etc. meant the chimes. Not sure what you meant about 2 different chimes. Did you mean a different sound, or is it for the different strikes. It plays the chimes on the quarter hour and a full strike with number of hours on the hour. Thanks for your help. Jeanne
  • 910 Answers
These clock do need oiling every couple of years and should be cleaned at least every 10 years.
One of the winding holes is for the time, one is for the strike and the 3rd is for the chime. These do vary in location from clock to clock so I can't advise any further. It sounds like this clock has 2 differenct chimes depicted by the SIE & EIV7.
I think your best option is to take it to a clock shop and get it cleaned. They should then be able to give you more information on the chimes and its operation.
Posted on May 30, 2011
  • 10,319 Answers
The center hole in every three holer I've seen - is for "TIME" - makes the clock run. Most all have the hour strike on the left and the melody on the right. NONE of these regulates speed ( regulation ) Now there are some clocks that have a double-ended key and there'll be a liddle eaky tweeky hole at the very top near "12" for "speed". That is the ONLY SPEED regulation on the FRONT of any clock I've seen. You may be aware that the clock speed changes as the spring unwinds. That's the physics of a spring - more power fully wound. But you don't regulate the speed by the amount of winding. You FULLY wind ALL three once a week if it's a ONE WEEK running clock.
  • 373 Answers
I don't know a lot about your clock, however, I do know that my grandpa back in the 1950's keep his coo-coo clocks running by once in a while sqirting graphite into the mechanism. You may be able to get graphite at a hardware store...I haven't seen any in a long time. Graphite acts as a lubricant. It is a powdery substance and usually dark gray in color. This might get your clock running once you can trip it back. I would insert the graphite in the winding holes or if you can get in the back of it and squirt it and then try to wind the holes that are not wound.
Posted on May 28, 2011
  • TV Doctor
    TV Doctor May 29, 2011
    Please accept my solution.
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I have a Revere 913 clock. Keeps perfect time. Westminster chimes only work intermittantly by itself. Can activate chimes manually. It appears that the functions are in order, but will not activate by...
    Hello Rterry6517,
    Yes... you are right (CLOCKSMITH / movements).
    Electric movements (original (telechron chiming type))
    are very much the same as SPRING DRIVEN...
    (in fact... the ones I have worked ARE spring driven
    Merely THE WINDER is ELECTRIC)).
    A CLOCK repair would be the wise choice...
    Some people opt for the electronic conversions...
    (my opinion they are quite a bit less of the true tones
    of a well maintained clock motor and REAL CHIMES.
    Hope THIS HELPS...
    Carnac the Magnificent
    Nov 20, 2017 | Watches
    How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
    If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
    Jan 16, 2011 | Watches
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
    Nov 19, 2010 | Watches
    I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
    mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
    Jun 23, 2010 | Watches
    Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
    You were not very specific about you clock description, Many of the German clocks were using auto correct features.
    You may not have this function.
    Move the hour hand to the correct hour.
    Hope this tip help you.
    R/
    David
    http://antiqueclock.clockstop.com/
    Mar 13, 2010 | Watches
    Antique Forestville Mantle Clock
    Middle Key hole for the time.
    Left side is for Chime
    Right side is for the strike.
    r/
    David
    Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Timex westminster anniversary chime clock doesn't chime correct number
    Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
    Oct 04, 2008 | Watches
    Watches Logo
    2,064 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
