Question about Swisher Zero-Turn Riding Mower 24 HP, 54in. Deck
I have a Simplicity Zero turn and it won't move. I
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Toro zero turn 52" commercial won't move but I can
is that push it around in your shop?
Apr 11, 2013 | Garden
The stops won't hold and the upright falls
The pedal and/or housings are worn. There are fixes for it. If you like Contact me and I can help. I need to see some pictures of the area.
Tim
TheVacCenter.com
Oct 28, 2012 | Simplicity 7250 Deluxe Vacuum
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
Simplicity Prestige tractor low oil pressure light is on and engine won't start
I have a 2006 simplicity it runs amazing and lows great however when I'm mowing an hour or so into mowing oil pressure comes across the digital screen on dashboard and then it just dies stops running after a minute or two it starts right back up and will do it as gain and again. Amy advice on everyone's experience or knowledge would be appreciated thank you
Jul 04, 2012 | Garden
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Swisher Zero-Turn Riding Mower 24 HP, 54in. Deck Logo
146 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
