Question about Polaris Pb4 - 60 Booster Pump
Need to replace bearings and seal in Polaris booster pump, pb4-60. Any idea where I can find instructions on how to do this? Thanks! Jim
    Top Expert:
  • Polaris Master
  • 4,290 Answers
Replace whole pump more economical most times
Posted on Apr 23, 2016
SOURCE: my polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at bbgreg@optonline.net good luck
Posted on May 31, 2009
flacooo1
  • 172 Answers
SOURCE: Looking for wiring instructions for the pb4-60 booster pump
if this is for your polaris booster pump they all have to screws to attach the wires if you have 220 volts it won't matter which wire goes where the longes the pump is rated for 220 volts if you have 120 volts pump is the same just make sure your wires are for 120 volts it won't meter which wire goes on which side just make sure you use L1 AND L2
Posted on Jun 16, 2009
john224
  • 1378 Answers
SOURCE: I have a Polaris PB4-60
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Posted on Jul 12, 2009
Coastsider
  • 331 Answers
SOURCE: Just bought a new polaris booster pump (PB4-60)
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Posted on Apr 14, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: How do you change the shaft seal on a polaris
BE CAREFUL YOU CAN BREAK THE SEAL PLATE BY OVER INSTALLING THE #1000 SEAL , TAKE 6 BOLTS OUT UNSCREW IMPELLER THE TAKE THE 4 BOLTS THAT HOLD THE SEAL PLATE TO THE MOTOR, KNOCK OUT OLD SEAL FROM SEAL PLATE USE SOCKET THAT FIT OVER SEAL. I USE A 1 1/4 SOCKET. THEN REPLACE CERAMIC IN IMPELLER (READ INSTRUCTIONS WITH SEAL) OR TAKE IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. HAVE HIM DO IT . $ AROUND 40.00
Posted on May 24, 2010
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
My pump has a high pitched whine. Are there likely bearings out?
Yes...as the motor bearings wear they will get louder and louder. A common cause for bearing failure is a leaking seal. If you have any signs of a water leak or if the pump seal is more than a few years old you'll want to replace that when you get the bearings.
If you are handy and understand bearing replacement you can get the parts for less than $20. If not, a typical repair at an electric motor repair shop for something like this is ~$80 if all it needs is bearings to get it going again.
John
Mar 01, 2011 | Polaris Pb4 - 60 Booster Pump
Is it a big job to replace the bearings in my pb4 booster pool motor (i am a mechanic). If not, does anyone have instructions (I don't want springs popping out etc)? Thanks
It is not complicated if you are a mechanic. You do however need a good set of bearing pullers, plus the bearings. Bearing pullers are not cheap, bearings are. If you plan to do many of these in the future, or have a use for a bearing puller, then it is worth the money. Otherwise, it will be cheaper as a one time cost to have it done by someone with experience.
If you do want to do it yourself, e-mail me here for instructions.
adamh@newconceptchem.com
Jan 20, 2011 | Polaris Pb4 - 60 Booster Pump
Once the booster pump (for polaris 280) is turned on, water starts to leak badly from the front.
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Oct 03, 2009 | Polaris 280 In - Ground Pool Cleaner with...
I am considering a repair to a polaris booster pump - replace bearings and seal. Is this too in depth for a DIYer ? do i need any special tools ? any tips on dissassembly/reassembly? Thanks for your...
just pay attention how you take it apart and make sure you put he new bearing in straight, you may need a bearing puller, and also maybe a vise to work out of
Sep 12, 2009 | Polaris 3/4 H.P Booster Pump
My pb4 booster pump is leaking from the booster pump bracket and making a ''whining'' noise when turned on????
Replacing the pumps mechanical seal should fix the leak. The whinning may be from bearing damage due to the leak. If you are unsure how to fix it, try a local electric motor repair shop. We charge about $55 - $60 for that seal and bearings installed.
Aug 26, 2009 | Polaris Pb4 - 60 Booster Pump
When running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
When running it makes a loud noise
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Polaris Pb4 - 60 Booster Pump Logo
227 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
