Question about Roper Dryers
Brand new roper dryer MOD RGD4440VQ1, Its gas and has a LP fitting how to change the LP fitting to PRopane. I have the conversion kit but can't find out how to install it
  • 8,197 Answers
According to the roper site you may not change to LP gas yourself. You will need to get a licensed LP technician to make the conversion. The reason why is that they will need to adjust the flow of the Lp so that the dryer will work right. If you do not get a Lp technician to do the work then you will for fit the warranty on the Dryer.
Posted on May 28, 2011
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
Can a roper gas dryer woek wirh propane gas?
Yes, but you will need to contact Roper or a local dealer so you can buy a propane conversion kit...they are fairly easy to install be need to be installed correctly for safety and so that everything works well...
heatman101
Aug 07, 2010 | Roper RGX4634KQ Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do i change an estate TGDS740JQ gas dryer to propane
they have gas to LP conversion kits online. just google for it. Its not a tough job if you have mechanical experience, otherwise call a pro.
Nov 06, 2009 | Estate TGDS740JQ Gas Dryer
I need to convert my gas dryer to propane. I
Here are the basics of the conversion process:
Make sure the gas is turned off and the dryer2.gif is unplugged from the power source. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Oct 02, 2009 | LG DLG5988 Gas Dryer
To convert from natural gas to LP
Check out the link that I am providing for information regarding the part you are looking for. http://www.repairclinic.com/Appliance-Parts?s=t-LDG712-%3d%3dc237
Make sure the gas is turned off and the dryer is unplugged from the power source.The first thing that you will need to do is purchase a gas dryer conversion kit. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in2.gif the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
Sep 29, 2009 | Dryers
Converting a whirlpool dryer from lp to natural gas
Sep 11, 2009 | Dryers
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
