Question about Pool & Spa
Rheem Pool Heater: P-M406A-EN-C Can't get it to come on. Code says "SNS - off". Can you help?
  • 11,800 Answers
SNS - off signals that a sensor is not functioning. In your model it's most likely the temperature sensor - it will have to be replaced and that is a job for the Rheem authorized service shop.
You can find the closest to your location here
http://www.rheem.com/Contractors.aspx?postalCode=
If you prefer to deal with Rheem directly then send them a message using this
http://www.rheem.com/Contact.aspx
Posted on May 28, 2011
Getting a sns code on control panel display. Where is the sensor located on this pool heater?
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
Apr 25, 2015 | Rheem M266A 266K BTU Pool or Spa Natural...
Where is located pressure switch
inside front panel has 2 wires and a tube going to it
Apr 25, 2014 | Rheem M406A 399K BTU Cupro Nickel Pool or...
Rheem pool heater, M406A, display has failed. It is only partially readable and has a dark spot inside it. Is the replacement part the PC board/controller? Is this a job for a savvy homeowner or call
The display is part of the pc board and it is very easy to replace. It is also fairly expensive part just to read the temp(around $400.00). If the heater works fine except for the display you can get by. Hit the up arrow button about thirty times this will ensure you have max'ed out the temperature at 104 degrees. From there with the down arrow you can count down to the desired temp. The mode button should work normally to turn the heater on or off as desired. This is obviously not the repair but it will buy time until you are prepared to replace it or have a technician out for another call.
Apr 12, 2014 | Rheem Pool & Spa
My Rheem model P-M266A-EN-C is displaying this: GVC. The heater isn't working. What does this mean?
GVC means Gas Valve Closed. This fault can be caused by many different problems, or even a faulty gas valve. Here is a link to a PDF file that give a step by step troubleshooting chart. This may help put you on top of the actual problem. http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/raypak-r-series-oim.pdf
Sep 03, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
I received a notice that the filter needs cleaning. How do I do that?
THis is a PRS code (clean filter/strainer) correct?
This simply means that either there is no water flowing through the pool heater (possibly due to a dirty filter)
If you know you have good water flow, then your pressure switch has failed. Replace the pressure switch.
May 31, 2011 | Rheem M406A 399K BTU Cupro Nickel Pool or...
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
1. Water temp is below 36 degrees F
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
I just purchased a home that has a Rheem Digital Gas Heater for my pool / spa (Model P-M406A-EN-C) 399k BTU. I cannot find a manual on the Rheem company website. Any idea how I can obtain one?
They have good listings on their web site.
http://www.rheem.com/product.aspx?id=8B064EC5-B708-4821-9F2B-DEF3A2243F90
That link should be to your model. When you click on the link for your manual (installation instructions)l, if it doesn't download. Right click on the link, and select download
So what is the problem?
Aug 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem Raypak Pool Heater P-M406A-EN-C Manual Need Manual
Go to www.raypac.com you can download manual from that site. Rus
Mar 10, 2010 | Heating & Cooling
Pool & Spa Logo
199 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
