Question about Ruud UBHC Air Conditioner
Compressor on Ruud Unit UAMA-042JAZ and its fan won't run. Electric comany said low voltage circuitboard problem. Suggested replacing the fuse on the circuitboard. I could not find a fuse, where would it be loacated?
  • 1,056 Answers
The units has what you call a contactor which is actually a relay but it does not look like a relay. You can get a none conducting material to depress it. and the compressor should run and the fan. Be very careful since that contactor has exposed parts and it has 220 volts running through it. That contactor coils is energized by low voltage current usually around 12 to 24 volts and it is supplied by a small transformer near the evaporator in the attic. There is a contact and when the contactor is energized magnetic field pulls it in so the contact on the 220 volts touches and the AC unit runs. Another word of caution, do not turn the unit manually one after another. this may damaged the compressor. Wait a few minutes each time you manually push the contactor to see the problem. Good luck.
Posted on May 28, 2011
Ruud a/c, fan works but no cold air.
if the outside fan is running you have correct voltage. compressor capacitors could be bad.
Jan 11, 2014 | Ruud Central System Air Conditioner
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
Ruud compressor relay not working a/c
Hello,im assumimg you are referring to the contactor coil on the oudoor unit. First you must verify if the coil is receiving 24 volts from the thermostat at the coil terminals, if not there is a problem with the low voltage circuit, possibly a a open thermostat wire or a fuse blown on the indoor control board. If ther is 24 volts at the contactor coil and it does not engages then the contactor coil must be replaced
May 24, 2012 | Ruud UAMB Air Conditioner
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
I JUST INSTALLED THIS UNIT AND IT RUNS FOR ARND 2MINS AT 135PSI LS AND 330 HS THEN SHUTS OFF.I HAVE CHECKED THE MFDs ON THE CAPACITOR,CONTECT,POWER AND THE HIGH PSI SWITCH ,ITS STAYING CLOSED SO I MADE A...
135/330 psig is obviously r410a freon, and good pressures, so I'd rule out a freon/circulation issue, unless these pressures change dramatically after 2 mins of run time. You'll need to make sure you're not loosing line voltage, as Thomas suggested. If that's good, the you'll need to monitor all low voltage safeties and relays without bypassing ANYTHING, unless you're skilled at troubleshooting, and can repair what you may break.
Aug 30, 2017 | Ruud UPMC036 Air Conditioner
My downstairs Ruud AC will not blow any cold air. The fan in the outside unit does run.
Is the compressor running in the outside unit? If it is then check the capacitor for the fan and replace if necessary. If it's good then check the fan motor. If the compressor is not running also, check the circuit breakers or fuses and the contactor in the outside unit. Let me know what you find or if this helps, please rate it.
Aug 04, 2010 | Ruud UBHC Air Conditioner
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
I am trying to get an electrical schematic of my RUUD 3.5 Ton condensing unit UAKA-042JAZ. The one that is attached to the inside of the unit's cover is not readable. Where can I get another drawing to...
thers 2 sides of power in the entire unit besides the 24 volt control wires! what are you trying to make run? theres a fan and compressor, both operated off the same contactor!!
Aug 22, 2009 | Heating & Cooling
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Ruud UBHC Air Conditioner Logo
326 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
