Question about Konica Minolta magicolor 2430 DL Laser Printer
Toner life end black - Konica Minolta magicolor 2430 DL Laser Printer
    Scholar:
  • 118 Answers
This means that you need to change the black toner cartridge.
Posted on May 30, 2011
Black ink leftside of paper
Black toner leaking, either the toner is low/finished, or drum is end of life.
Sep 04, 2014 | Brother MFC-9120CN Multifunction LED...
NOW ITS PRINTIND DOTTED LINES
An 1118 process unit has a 100k life @5% average coverage in my experience the usually last about 85k when the waste toner is full it's generally near the end of life of the unit the fact that you're getting black marks in the pages says to me that there is drum decay which is also a signs of the process unit life nearing its end
Mar 22, 2014 | Kyocera FS-1118MFP Laser Printer
Says toner life end and it's not ended. thanks. I also never reset drum button when got new drum how do i do that as well? thank you :)
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
Apr 14, 2011 | Brother DCP-8065DN Black and White Copier
The copies come out with black spots and toner on the paper.
Black spots on the document usually is caused by either a leaking toner cartridge. A PC drum that is at end of life. Or as simple as spots on the document glass.
Don
Jan 05, 2010 | IBM Infoprint 1120 Laser Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner end life
There are silver wire contacts on the left and right that are spring-loaded and touch on copper tabs on the cartridge. They may not be making proper contact. Wiping with some contact cleaner ona cloth may help, or failing that try brightening the surfaces with some fine Scotchbrite pad to help them make proper contact.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
96 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
