Question about Coleman Electrical Supplies
Cant start coleman powermate vantage 3500 - Coleman Electrical Supplies
  • 5,603 Answers
Pull the spark plug and see if it is wet or smells of fuel. If not, then may have issue with the carburetor, fuel filter, float, etc. If plug appears fouled, replace the plug with new one correctly gapped. I have found that one can put an UNLIT propane torch into the carburetor and try starting. The propane won't flood the engine and can give an indication if the ignition is working. If the engine tries to start on the propane, then carburetor work is in order. Usually a problem with the float. Fuel filters and the embarassing thing of forgeting to turn on the fuel valve are farther down the list.
Posted on May 28, 2011
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How do you flash a Coleman Powermate 3500 generator? Runs fine; no electrical output
See some of my responses to other peoples generator problems.
If you have no or very little electrical output, then you have overloaded the generator by placing a demand for too many amps from too many appliances for the size of the generator. You will have blown a capacitor, resistor, or similar item. Someone with a good electrical background will need to diagnose the problem and find the blown part.
Dec 04, 2013 | Coleman Powermate Premium Plus 6250W...
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Nov 05, 2012 | Coleman Powermate Powermate 5000W...
Problem with the Coleman Power Generators I have a Coleman Vantage 3500 motor runs no generator output what if it doesn't have brushes?
My owners manual says to take it to a service center to get the generator "excited" if it has no brushes. Hope this helps
Jan 19, 2011 | Coleman Electrical Supplies
Older Coleman 3500 Watt generator, sitting for over 2 years. engine starts and runs normally, but no power generated.
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Jan 05, 2010 | Coleman Powermate Powermate 5000W...
Generator will start and run easy, then just die.
Check for loose wiring connections, especially at the run or kill switch. Generators vibrate a lot so it could be as simple as something loose.
Jun 15, 2009 | Electrical Supplies
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
441 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
