Question about Tefal Aquaspeed 170 Iron
Brown liquid is coming from my iron it is a tefal aquaspeed 170, need to clean it out....how????
  • 1019 Answers
SOURCE: tefal Aquaspeed 150
yes unless the thermostats gone.
It,s not really financially practical to replace parts, will cost you parts-and labour.
cheaper to get a new iron, unless still warranted.
Mike @ Compurepair.
Posted on Feb 22, 2008
SOURCE: How to dismantle a Tefal Aquaspeed 150
Re. getting the power cable out - the rubber-cased unit simply pulls out from the main body of the iron. I had exactly the same problem with our iron and fixed it by bending the brass mounting ever so slightly so that contact was made again.
Posted on Apr 02, 2008
t0pc4t
  • 132 Answers
SOURCE: Hi, My Tefal Express Steam
Do you use any additive to the water when you iron?
Do you empty the water out after use ?
Brown steam / water suggests foul water, or rust due to dirty water pipes on Iron.
With regards to 'not working' - do you have any lights on, or is it dead.
(I had one of these, the mains lead within the flex holder had broken - design flaw) - managed to repair.
Posted on Aug 16, 2008
SOURCE: tefal express iron cleaning
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Posted on Aug 23, 2008
SOURCE: how can i clean my tefal iron/ surface
tough soapy sponge
Posted on Dec 27, 2009
I need to know how to descale my iron
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 13, 2011 | Tefal Aquaspeed 155 Iron with Auto...
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
What is the energy consumption of this iron
ans 8 amps or 1500 wates / max . only when heating .. on stand by it 50 %
Jan 16, 2010 | Tefal Aquaspeed 170 Iron
Clean the iron
can you not read properly i said i followed the manu advice on cleaning and no good
Dec 31, 2009 | Tefal Aquaspeed 170 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Tefal Aquaspeed 150
Mike @ Compurepair.
Oct 01, 2007 | Tefal Aquaspeed 170 Iron
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Tefal Aquaspeed 170 Iron Logo
55 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
