Question about Astoria Argenta SAE-2 Espresso Machine
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our espresso shots are coming out way too short. Do we need to replace our boiler?
    President:
  • 1,618 Answers
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
Posted on Jun 02, 2011
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
Tip
Boiler Leaking Water - The Boiler Leak may not be the boiler
Went on one call today and had another query by Facebook about this so I though why not write an article about it. Both persons were very concerned as they saw water dripping from theirs boilers. A closer inspection for both showed that it had nothing to do with the boiler its self.
There are many things that can make water leak from your boiler. If you know for sure that the water is coming from a hole in the sections then you may have a serious problem. Usually though there is an easy fix for that also, more on that in another article. Both boilers today were leaking water from the relief valve.254c728.jpg
This valve is design to relieve the excess pressure from the boiler in case of a build up of extra pressure in the boiler. The extra pressure can come from a number of different things. A few of the causes may be a bad expansion tank, a bad fill valve or pressure reducing valve, or an open bypass valve. The bypass is easy, just close it and relieve the extra pressure. The others are not as easy.
Your expansion tank is simply a tank that allows water from the system to go in and out according to the pressure in the system.610ab3c.jpg This tank contains about ½ air which acts as a cushion to absorb the extra volume of water that is created as the water is heated. Hotter water takes up more space or volume, so it needs a place to go to when it is heated. If the expansion tank is totally full of water then, it will push water out of the relief valve. Changing your expansion tank will fix the problem.
If the reducing valve or fill valve is leaking by then you can also get extra pressure in the system.8e5ccb4.jpg A normal heating system will only run 10-20 psi pressure. Most well systems or city water is way higher than that. If the pressure in your boiler gets over 30 psi then it will begin to relieve the extra pressure by dripping water.
If you have a drip from your boiler this is what you check. First the expansion tank, the reducing valve, and the bypass valve that bypasses the fill valve. This valve is usually installed to quick fill the system, or purge the water lines of air.
Often there is just a small problem that looks like a big problem. Do not get excited and methodically check through the possibilities. You will usually find that the problem is not nearly as bad as you first thought that it was.
on Dec 06, 2009 | Heating & Cooling
Pressure on my boiler gone to 0 how do i get my pressure back up
Turn the burner back on & make sure you have correct water level in the boiler.
Dec 15, 2013 | Water Heaters
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
BOILER COMES ON AND SHUTS OFF IN A FEW MINUTES
Check the flame control if any.
The pressure is coming up or not?
Jun 14, 2010 | Cleveland 208/3 Phase 24CEA10 SteamCraft...
Hi, I need your help please. I have steibel eltron gas boiler. Heating radiators and hot water. The water is leaking from the bottom of my boiler. It is orange / brown water. It stops dripping when the...
Either a seal or casting itself is cracked and leaking. Going to have to replace. Or they do make powder that will seal the leak. Most plumbing or HVAC suppliers do carry this. I have had to use it a few times and has never let me down.
Mar 27, 2010 | Heating & Cooling
We have a Worcester Bosch Highflow 400 (10 year old) combi boiler. Over the last few weeks when we have put on the heating the boiler kicks in and fires up and the heating comes on (the water comes on fine...
The by pass pipe may be limed up. This apparently causes a reduced flow which will stop the heating side of the thing working. Call out Worcester Bosch engineer. It costs £210 including VAT and most parts and they almost guarantee to get it working.
Nov 06, 2009 | Ruud Matching Split Air Conditioner
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Re-pressure Vaillant Turbomax Plus boiler
two pipes coming into boiler on right hand side have brass block valves with a small round recess. These two valves are linked with a stainless fill hose.
Inside the recess on each valve is a small slot, there is a "key" with the boiler but prob lost with the manual. The advantage of the key is its sized so you wont be poking it in the wrong place!
Using a screwdriver turn both slots throug 90 degrees, you will hear water running through. Sometimes one valve is left open so try a combination until the watert runs.
Keep an eye on the pressure gauge and dont let it get too high, if you have no idea of setting pressure head for about 1bar.
Apr 04, 2008 | KDS Valiant 6380iPTD-01 Notebook
Astoria Argenta SAE-2 Espresso Machine Logo
345 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
noel
noel
J.D. Browning
J.D. Browning
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
