Question about Dryers
A knocking noise each time the drum rotates - Dryers
  • Dryers Master
  • 7,482 Answers
Hi bob jordan6...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on May 28, 2011
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
Dryer drum is starting to make a thump, thump sound when rotating. Everything else works fine. Belt is good.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 26, 2011 | Dryers
My Frigidaire electric dryer, when is running, makes thumbing sound, similar time spacing like the rotations of the drum, and there is nothing inside that would make that noise.
heatman101
May 02, 2011 | Frigidaire Dryers
Scrathing noise in the drum when rotating sounds like a belt
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Mar 06, 2011 | GE Dryers
VTD000 UNEVEN DRUM ROTATION BANGING SOUND
heatman101
Dec 16, 2010 | Zanussi TC7102W Electric Dryer
Neptune dryer makes a banging noise on the left side each time the drum rotates
heatman101
Dec 12, 2010 | Maytag MDE9700AYM Electric Dryer
Squeak as drum rotates not the agitator in the middle? Bearing or motor?
heatman101
Sep 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
Knocking in trany during agitate/wash cycle
Probably a bad tranny or bad bearings on the tub.
Mar 12, 2010 | Washing Machines
Drum Noise
heatman101
hjdj
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
