Question about Dell Inspiron 1501 Notebook
Dell batteries. my dell inspiron 1520 stopped charging. the charge light shows that its charging for about 2-4 seconds, then flashes as if its dead a few time, then goes back to acting as if it were charging. This continues to repeat and i cant get it to charge up enough for me to use it. On a thread you said that you took out the battery and tested it, but how do you test a laptop battery? NOTE: it says dell inspiron 1501 pc note book, but it's actually a 1520. it wont let me submit this as 1520.
You could have the same roblem that I have.
I tried charging the battery on another 1520 and it worked OK
my prob is the PSU although working OK isn't geting to the computer/battery
looking for a protection diode but cant find it.( if protection diode goes all power goes to earth). If you find a circuit for the motherboard please let me know Tom
Posted on Sep 02, 2012
Its time change ur batteries
Posted on Aug 18, 2008
My laptop not starting up on pressing start buttton.
ensure it's fully charged.
plug in AC
if that doesn't work, plug out ac, remove battery.
hold power button on for 30 seconds
put battery back in, then AC
if that doesn't work, either AC adapter is broken and not charging the PC, or else motherboard is dead.
Nov 11, 2014 | Dell Inspiron 1520 Motherboard
Tip
Laptop Battery Won?t Charge?
If your dell laptop computer runs normally on the AC adapter, but the battery won’t charge, please try the following troubleshooting steps:
Check the dell laptop battery and Connections:
1, Remove the battery from the system.
2, Look at the connectors in the bay and on the battery for signs of physical damage.
3, Check the battery charge by pressing the status button or image on the battery near the LED’s.
Note: The lights indicate the current amount of charge on the battery. If all the LED’s come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
4, Reinsert the battery; push until it locks into place and the latch snaps back to the locked position.
Swap Bays or Try A Second Computer:
1, Some systems can run with the battery in either bay. Try swapping bays if you have one of these systems.
The following systems permit a battery to be used in either bay:
Inspiron systems 3700 3800 7500 4000 4100 4150 8000 8100 8200 Latitude systems CPx H CPt V CPx / CPt C600 C610 C640 C800 C810 C840 Note: It may be necessary to slide the face plate left or right on some batteries when switching bays. 2, If you have access to a second computer like your own, try to charge your battery in that system.
Flash the BIOS:
Flashing the BIOS can correct many hardware issues.
NOTE:Dell recommends that you update the BIOS on your system, only if you are having problems
1, Go to “The Dell support site”
2, Be sure your system is the one listed in the Your System section on the left.
3, Click the Downloads tab
4, Choose your operating system from the drop down menu
5, Select FlashBIOS Updates as the download category.
6, Click Go.
Select the link to download the most current version of the BIOS:
1, Save the program to your desktop.
2, Go to the desktop and double click the icon.
3, You will be given the option to either create a BIOS disk or flash the disk from the hard drive.
Run the Recalibration Utility if Your System has One:
This utility runs the battery all the way down and then recharges it completely. The process takes several hours so it is best to run it overnight. Use only the recalibration program specified for your system. Using any other program could void your warranty!
Latitude LM, Inspiron 3000 and Inspiron 3200 systems use this recalibration program: BATRECAL.EXE
Inspiron 5000, Inspiron 7000, and Inspiron 7500 systems use this program: I75BRCA0.EXE
Latitude LS, Latitude L400, Latitude X200, and Inspiron 2100 enable a recalibration option on the Power page of the BIOS Setup Program:
How to Enable Battery Recalibration
Try to charge a second battery like your own if possible.
If the second battery won’t charge, the problem may be caused by the charging system in your computer.
If the battery still won’t charge after you have done this troubleshooting,it mean you should replace your old battery,you can go to www.sales-battery.com to choice a new dell laptop battery replacement
post via:dell.com
Battery purchase information:
US shop
http://www.sales-battery.com/laptop-batteries/dell.htm
UK shop
http://www.global-battery.co.uk/laptop-batteries.htm
need Universal External laptop battery
http://www.global-battery.co.uk/universal-external-laptop-battery.html
http://sales-battery.com/External_laptop_battery.html
on Jun 15, 2010 | Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
311 people viewed this question
Alun Cox
