Question about Apple iMac G5 Desktop
Do you charge a fee???? my friends imac g5 A1058 17" monitor 2 ghz processor, it just started freezing computer was purchased 3-4 years ago..is there a built in utility for scanning the imac?
    President:
  • 2,992 Answers
Chances are that your friend's computer has a hardware problem, not something in software that you can scan for. Capacitors on the main board that go bad are a common source of many problems, including freezing and no startup.
It's a fairly simple matter to replace the bad parts and get the computer going again, although some experience with electronic repair, soldering, and the proper tools are required to prevent damage to the board during the repair.
Several sites offer information about how to open the computer, showing where to find the usual culprits, and giving pictures of what the caps look like when they are bad. There are several with videos as well. Kits that give you all the capacitors needed are available from several sources. Here's the place I used, but you can find others.
Good luck with the repair, and thanks for using Fixya!
Posted on May 28, 2011
Android File Transfer
Hi Kim,
Yikes, an Android phone on an iMac G5...
It is probably an upgrade or an update that was not compatible with the G5 Processor... That machine is going on 10 years old now...
Try connecting it to another computer, a friends or at work, to see of it connects properly... if so, it's end of the line for G5's ;-(
May 27, 2013 | Apple iMac G5 Desktop
Why does my iMAC 4,2 reject blank DVD-Rs but plays burned DVDs?
Your machine has a DVD-rom drive, but not a DVD-burner. There is a difference.
Basically, you can read and play the DVD's, but the drive is not capable of burning them.
Nov 04, 2012 | Apple iMac G5 MA064LL/A Desktop
About 6 months ago there were 2 colored vertical lines on my desktop screen. I've been getting more lines every 2 or 3 weeks and now have a total of 18. The nearest Apple store said they can fix it no...
It should not affect the data on the hard drive but with all repairs such as this it always worth making sure you have your hard drive backed up. I had a similar problem with a imac a couple of years ago and the hard drive was fine when it came back. Hope this helps.
Nov 14, 2010 | Apple iMac G5 Desktop
All of a sudden, my iMAC wont turn on.. Any suggestions???
It is best to check with an Apple store, assuming there is one within 100 miles or so, especially if you are under AppleCare, yet--unlikely. My 20" iMac G5 gave up the ghost a year ago. Their cost to repair/replace the logic board was >$800. I've heard 3rd party as low as ~$500. I decide to change to an MacBook 13" (Early 2009 white, then current) and love its convenience.
Try the Macintosh boards where I have posted http://discussions.apple.com/category.jspa?categoryID=134 "Apple - Support - Discussions - iMac G5". No luck for me though. If you have the early G5 that I have, pull power plug and any cables, place face on non-scratching surface, rotate 1/2(?) turn the 3 screws on the bottom, lift off the back and stand, use the power cord to try to start it. There is a button for this but varies with models. If only one LED lights or 2 for a short time you may have my problem. First, after the back is off check if the capacitor tops are bulging. If so that is a known repair, but its coverage expired.
-Ken
Apr 11, 2010 | Apple iMac G5 Desktop
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Imac G5
Check the Memory9RAM) on your computer.
Jul 24, 2009 | Apple (661-2795) for iMac Motherboard
While trying to install OS10.5 and it will attempt to but it freezes, you the Apple booting circle it stops.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
May 20, 2009 | Apple Computers & Internet
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
Can't reinstall
uninstall the antivirus and unused softwares and then try
Feb 20, 2008 | Apple Power Mac G5 Desktop
Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Nov 10, 2007 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
81 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
