Question about Photography
Focal tripod Hi, I have a Focal (K-Mart) model# 20-08-87 that has broken leg locks. They are lever type. Can't seem to find repair parts. Thanx for any help. Steve On my old Kalimar tripod, the leg locks have two little pieces of metal and one piece of something that looks like a chunk of hard plastic. I can't seem to put the pieces back the right way, because the clamp will no longer close. (Appears to be too tight a fit.) Can anyone tell me exactly how the metal and plastic shims work, so I can reassemble my much-loved tripod? Thanks.
  • Anonymous Dec 27, 2008
    I also have a focal 20-08-87 with broken leg clamps
  • erikbruflat Feb 27, 2009
    tripod leg extension lock is broken, is this covered under warranty, is the focal company still in business?
3 Suggested Answers
SOURCE: Focal tripod
There is a small piece of metal that wedges between the latch and the leg. It is pretty thin, yet strong, and curves in the middle. If you bend some pieces of metal and cut them to fit into these latches, they should work again. I'm sorry I don't have a picture at this time.
Posted on Apr 24, 2008
I have a Focal tripod model # 20-08-87 that is missing the quick release plate. I cannot seem to locate a replacement. Can you help me locate one??? Thanks, Jackie
Posted on Jul 21, 2009
How to repair take up lever
How to fix your tripod if its broken - YouTube
? 12:23
www.youtube.com/watch?v=zQfMik-2sTE
Dec 15, 2013 - Uploaded by Chris Rubei
Why was i fix my broken tripod. ... Repairing the aluminumlever tensioned tripod legs Velbon HG4.wmv - Duration: 2:41. by wtam69 1,535 ...
Aug 28, 2015 | Photography
Is there a "lock" position on on the 3 leg spread of this tripod?
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
Aug 25, 2014 | Velbon Aef-3 Tripod
The leg clamp on my tripod is broken i need to find a replacement
They were not made to be serviced. They were made to be disposable essentially, but you might contact the folks at B&H to see if they may have a solution.
Otherwise depending how it broke, it might be able to be cemented, or reconfigured to accept a different type of clamp. I had a no name type of tripod that required some caredul filing to restore a lip on a clamp so it would lock after the original lip snapped off.
Jul 07, 2012 | Dynex 60" Universal Tripod
One of my leg locks is broken off, can it be replaced? this is a davisi and sanford courier xxt
Yes, I believe so. This tripod is made by Tiffen.
Here is the product brochure
Here is a link to the Davis & Sanford Tripods forum. This is actually linking into a specific "Broken Tripod Leg" post where a rep of Tiffen posted theoa message
Here is Tiffen Parts & Repair
and... you could just try the Contact Us if all else fails.
Good luck with getting it repaired! Seems like something that appears to only be 5 years old should still be supported.
Mar 02, 2011 | Sanford Davis & Courier XTT 67 Heavy-duty...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Vivitar tripod V900 has a broken friction level
Vivitar has been out of the tripod business for a few years now. They may no longer have the parts. You may be able to find another V900 and scavage the parts. Make sure the model numbers match exactly. The V900SE is a different year and does not share the same parts as the V900.
Jan 01, 2009 | Photography
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
Focal tripod
Mar 01, 2008 | Sanford Traveler Tripod
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Photography Logo
427 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
