Connect a set of RCA audio and video cables to the color-coded outputs
on the back of your Samsung VHS/DVD player. The colors of these cables are
yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to
the color-corresponding inputs on your television. When plugging in these
cables, look for a label for the input, such as "Video 1" and
"Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step
3. If you did not take note, you can also tune through your television's input
channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the
"Play" button to verify that the unit is functioning properly.
Component Video
Plug the power cable of the Samsung VHS/DVD player into an available
power outlet near the television.
Connect a set of component video cables to the color-coded outputs on
the back of your Samsung VHS/DVD player. These cables will look similar to
composite audio and video cables, but they are instead color-coded as red, blue
and green.
Plug the other end of the component video cables into the
color-corresponding inputs on your television. Take note of what input number
you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your
VHS/DVD player, then connect the other ends to your television. These cables
are color-coded as red and white and must be plugged into the same input number
as the component video cables.
Tune your television to the component video input channel where you
connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play"
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
