Question about Dishwashers
Dishwasher stopped cleaning white residue i was told to check the heater not sure how when dishwasher is running theres only about 33 volts to element is this correct element does not get warm at all
  • gasshydro May 28, 2011
    is there anybody there all i want to know is how much voltage is there to be at heater element
  • 5,081 Answers
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Posted on May 28, 2011
  • 1 more comment
    so how much voltage should there be to the element when washer is running
    were is the filter
    can you tell me what the voltage is supposed to be the the heater
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
I used my dishwasher for the first time today and my dishes came out foggy, there was still a soap residue
If your dishwasher has one of those reservoir's for JetDry...Try adding some of that. You could also pour one cup of white vinegar into the bottom of your dishwasher and then run it through a cycle on the highest level of heat possible to make sure the dishwasher is clean of any manufacturing residue etc.
Feb 03, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My dishwasher does not clean right it leaves small bits of food and residue had a technician look at it at the toone of 75 dollars and told me there was nothing wrong with it.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
0-0
Jan 03, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Dishes have residue..how do I run the cycle to clean the machine only..there is a clean button but does not light up when pressed..does it have to be pressed along with another button...
heatman101
Oct 11, 2010 | Jenn-Air 24 in. JDB1270AW Built-in...
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
Bosch shx33a05uc/14 dishes are milky with white chalky residue. Have cleaned the inside, and checked to make sure the water can exit the spray holes in the circulating parts (top and bottom). Checked...
heatman101
May 11, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Our Maytag Quiet Series 400 has stopped getting the dishes clean..It leaves residue and food on the dishes.My husband has taken it apart and there is nothing that he can find that might cause this.We have...
heatman101
May 03, 2010 | Maytag 24 in. MDB9750AW Dishwasher
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Motor and pump replaced still not getting dishes clean
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
