Question about Briggs & Stratton Garden
I ran my mower out of gas and I know I had some water in the tank. I filled it wirh gas and 350 ml of isopropyl yesterday and it still won't start today. It fired up twice yesterday but stopped right away. I ran the battery down again this morning and it never fired. I have put a new plug in, and drained the sediment bowl on the carb twice? Any ideas?
  • 4,348 Answers
Your condition sounds like a particle may be plugging the carb. IF you have good fuel flow to the carb, then take the carb apart and blow out any passageways. While there, drain all fuel and put in new fuel.
Posted on May 28, 2011
Testimonial: "I got it running before I read your e-mail and I can tell you you are 100% correct! Keep up the good work!"
We used our trailmower once and it ran out of gas filled it up and it hasn't started since why not?
I would say you have water in your gas. Drain your system completely, gas tank, fuel lines, and most of all the fuel bowl at the bottom of your carburetor. You should be fine. GOOD LUCK FRIEND.
Sep 15, 2014 | Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
I filled my 2002 pt cruiser up with gas and drove 3to4 blocks and without warning it went dead and won't start back up please help if you can, I don't even know where my fuel pump is.
You could have an issue with water in the fuel. I have seen this before. I have seen several cars at the gas station that all filled up at the same time while a truck was filling the bulk tanks and several either could not get off the lot or ran terribly until they made it home. The fuel pumps in the foreign vehicles usually are accessable through the floor through an access hole directly above the fuel tank under the carpeting or floor mat, whatever is there.I dont know if they all do this. If you do not see a way to access fuel pump, you will have to drop the tank down to investigate.
Sep 03, 2011 | Car Audio & Video
I think I may have gotten some water in the engine after last use. There is oil on the floor of the garage after I used the mower last. The mower will not crank. What should I do? Thanks
I think that your problem is with water in your gas. Remove the rubber line that goes to your carburator and drain into a clear container , if there is water in your gas you will see it. Next if you have a bowl under your carburator, loosen the bolt and empty the bowl. Replace every thing you remove and fill tank with fresh gas. Oh, also change the oil while your doing all this fine maintanence, it won't hurt.
You can do it. GOOD LUCK.
Aug 24, 2011 | Husqvarna 5521BBC 961430013 21"3N1 BBC VS...
My Cub Cadet Riding lawn mower ran out of gas. When I try to start it only the engine turns but it won't start. I tried putting more gas but it still would not start.
If you blow in the tank with your mouth it will put pressure on the fuel and force it through the lines and cause the carburetor to fill. You should then be able to start the engine.
Jun 04, 2011 | Garden
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
116 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
