Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
Changing Freezers We have bought a new freezer. Our old one is beginning to make "funny" noises and we thought we should change before it went out. When the new freezer is delivered and we plug it in, how long should we let it run before transferring food from the old freezer to the new one? An additional problem is that we would like for the store to take the old freezer and dispose of it. Can we transfer frozen food immediately?
  • 828 Answers
If your products are already in the frozen state the answer is yes, you can make an immediate transfer. Normally a couple of hours run to allow the temperatures to stabilize is sufficient. The cool down run time also insures the the unit is functioning properly. If you plug it in and transfer the products right away make frequent checks to insure proper operation.
Posted on Sep 14, 2008
Master-Bilt commercial freezer Bearings
If you can access the condenser fan, jam it with a screwdriver handle so it can't revolve. switch on and see if the noise still appears. If not, change the fan motor. If so, change the compressor.. Don't let the compressor run without the fan operating more than to test for the noise.
Apr 25, 2014 | Freezers
My freezer's motor is making a funny noise what does it mean
It probably means it has a bearing goin out in it they are usually pretty easy to replace if you go back to the store you bought it from thay should be able to order oyu a new one it is something that is reasonable priced at least on most occasions,.
Nov 12, 2010 | Freezers
Got zanussi whirpool upright freezer afg8080/1x temperature gone to high is it worth getting repaired or buy a new one? freezer has been making a cliking noise and food is starting to defrost
if the freezer is over 5 years old,buy a new one under counter freezers not built in are fairly inexpensive and will cost less to run.fault sounds like temp sensor....
cheap part/labour intensive.....
Feb 13, 2010 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Freezer stopped cooling.
I hope the compressor isn't trying to come on. Best bet is to call a tech. If it is much ollder than 10-12 years old, you may be seeing the beginning of the end.
Feb 17, 2009 | Freezers
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frost free fridge hotpoint
Hot mamamia,
Huuum her to give you good advice.
You said,
When i switched the fridge on it was making a buzzing noise every few minutes kept it on for 24hrs but still did not freeze it was too warm have been changing the temp of it but still nothing . It was bought 2nd hand but was definitely working as it came from family.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 16, 2008 | Freezers
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
Brand new freezer
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
May 19, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
121 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
