Question about GPS
I need a new gps antenna to my Navman tracker 900, is it the same as Garmin has? We live in Sweden and I cant finde anything about antennas at google! Please help I dont wont to by a new!
SOURCE: garmin astro 220 gps dogtracker
garmin, it seems to me that your techs should be able to correct this problem by mounting the antenna in such a way as to place it in a fixed position where it could not be turned internally and cause damage to the unit with a force as small as hand tightening.
Posted on Jun 08, 2008
SOURCE: ANTENNA UNIDEN MYSTIC
Good News!!  I just received the email from Jessica at Uniden but when I called to place the order, I learned they are back-ordered( 550 Units) and are not scheduled to arrive until Nov 28, 2008.
So hopefully we will get them.  There is a $10 shipping charge in addition to the antenna.
L Meier
Larry,
Thank you for your inquire. I apologies for the information you may haven been given. But You are able to order the antenna for this model. They part your needing is part number BATY0461001 Cost is 27.16. This part is on back order. If the jack that the antenna screws on to is also damaged you most likely can buy this part but there are no instructions on how to install it.
To send the unit in due to the jack being the damaged part. You would be asked to box the unit up attaching a note explaining the problems your having along with a check or money order for the flat rate repair fee of 59.95. This amount includes all parts labor and return shipping. The unit will then carry a 90 day warranty.
Posted on Aug 01, 2008
SOURCE: Replacement antenna and flat cable for Nuvi 370
I could not get a Nuvi on ebay for a reasonable price and I was still leary about switching the cable and having the same problem so I just listed mine on there and sold it. I changed from Garmin and bought a Navigon 5100. Once Garmin eliminates the flip top antenna I might consider buying one again but right now my Navigon seems to be a really good unit. Thank you for your help.
Pete
Posted on Sep 25, 2008
SOURCE: navman gps tracker 5110i . lost the operation manual
Look Here....
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
Mark
Posted on Dec 17, 2008
  • 16 Answers
SOURCE: navman tracker 5100i keep loosing gps signal and
NAVMAN F10 WILL NOT ACQURE GPS SIGNAL EVEN AFTER RESETTING
Posted on Nov 24, 2009
Antenna problem
You may presume right, or you may presume wrong. I checked the manual and there are a lot of things to do get the system running. I suggest you take a look at the manual. If that does not help you solve the problem, you can buy another antenna.
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5x_series/MN000192C_TRACKER5600_Eng.pdf
Jan 13, 2014 | Navman Tracker 5600 GPS Receiver
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
Garmin Quest antenna broke of while quading need new antenna where to?
The best thing I can recommend is shop around on Ebay and hopefully find a basketcase Quest or Quest 2 with the antenna intact. Swapping the antennas is fairly easy. Lay the GPS display side down and remove the two endcap screws on the right side. Pull the old antenna out and to the right and replace it with the replacement antenna. Another option you may try is purchasing an external patch type antenna that can mount remotely and plugs into the back of your Quest GPS. Garmin WILL NOT sell you a replacement antenna. They want you to send it to them for repair and will charge you $100+.
Oct 05, 2010 | Garmin Quest GPS Receiver
Will not lock on satellites
First go into your menu and find GPS then go to restart gps and enter and see if it will reset. If not you will need to up date your unit as I am going to have to try once I recive the one and only card that the tech has to try this. Navman has been bought out by Norhtstar and you can call 1-800-628-4487 for support. They are eastern time and I did not get their open hours but I called at 6:50 AM PST and was able to talk to a live tech for help. The card that he sent will be here next week so I will be able to try fix on the Sat after as our boat is at its summer home. If my (or your) unit is too old then he said this too may not work but first try the restart GPS. Good luck, if it does not work for me then I buy a new and better unit as there is a flat rate charge from Northstar to repair of $350.00 !!!!
Jun 08, 2010 | Navman Tracker 5500X GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Aug 10, 2009 | Navman Tracker 5600 GPS Receiver
Ique 3600 does not work why?
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Apr 28, 2008 | Garmin iQue 3600 GPS Receiver
Will not aquire satellites
okay so its a miracle. the nuvi is working again. the same week it stopped working (my previous post) i decided to make to trip to NY (i live in MA). halfway through CT almost getting to NY my nuvi kicked in again and started working perfectly again.
the problem did begin after i did the firmware updates and even after doing the hard reset nothing happened.
but i guess going for a long trip fixes it. well it fixed it for me. back in MA and no issues so far. i dont know how that makes sense but it worked.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
90 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
