Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
How much oil goes into a Briggs and Stratton Model # 185432-0606-E1, its on a portable Generac Generator Se5000.
4 Suggested Answers
  • 376 Answers
SOURCE: Fuel in tank going into engine and mixing with oil
The float needle and seat are leaking and not shutting off the fuel when carb bowl if full. It then flows down the intake into the cylinder, past the rings and into the crankcase. Have the needle and pressed-in brass seat replaced. Could save yourself some money if you removed the carb yourself and took it in.
Posted on Jun 12, 2009
SOURCE: How much oil goes in a briggs and stratton Model
maintenance instructions says 36 oz.
Posted on Apr 25, 2010
SOURCE: oil in carburetor 14.5 briggs stratton.... why
Worn valve guide on intake valve allowing oil to backflow into carb.
Or...overfilled with oil and breather is pumping it into carb. Check oil level and adjust by draining some.
Posted on Jul 01, 2010
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
Briggs 5550 model 030253 generator spits oil
I'll take guess here, broken ring. You did mention where it was spitting oil from? GB...stewbison
Sep 05, 2011 | Briggs & Stratton Power Products 5,550...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Looking for a replacement battery for a Generac protable generator #01470. Users manual calls out part number 193043GS Generac does not recognize this #, at least onlnie.
Try that number through a Briggs and Stratton parts dealer. Your generator is now owned by Briggs and Stratton Power Products division.
Feb 17, 2011 | Garden
I have a 5550 generator and all the sudden the power outlets stopped working. I pressed the reset buttons and nothing. I hooked my electrical device to another generator and it works. What is the problem...
Hello, it sounds like either you have a voltage regulator failure, the rotating field coil is shorted or opened, or the exciter windings have failed. No easy answer because there are a number of issues here as you can see. Depending on how old the unit is you might have warranty. I would suggest you take it to a generac service center to have it checked out. I have 30 years experience with generac units. If it is a voltage regulator issue, (this can be expensive) you can get a jobber regulator. This link is for a good generic substitute. http://www.mcphersoncontrols.com/html/mcp_products/voltage_regulators/MTS63-4.html
I have used this regulator on 4000 watt to 50 kw units successfully. If it is a winding, then to rewind the stator part of the generator is expensive and a new generator is cheaper.
joe
Jan 15, 2011 | Briggs & Stratton Briggs Stratton 6200...
How much oil is required for 6.75 hp briggs and stratton engine on a 3750 generator?
Probably about 750cc / near 3/4 of a quart. Make sure generator is on level surface, add oil in small amounts and check using dipstick until shows full.
Jun 09, 2010 | Briggs & Stratton Power Products 5,550...
I own a Generac power washer model 01292=1 type 6670CP GPM2.9 PSI 2300 and request the owners manuel for this model Thank You Al Bonfardino albonfardino@yahoo.com
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Apr 30, 2010 | Briggs Garden
My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Jan 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
May 08, 2009 | Electrical Supplies
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
225 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
