Question about KitchenAid Ovens
My Kitchen Aid KEBS247DWH4 double wall oven will not work. I was using the convection bake cycle in the upper oven and the regular bake in the lower. Both ovens shut down and I have error F2 E0. I shut power off to oven, then restarted. Neither oven will work...displays F2 E0. Is the problem the keypad or the electronic control panel?
  • 1 more comment
  • kgschultz6 May 28, 2011
    Is this something we can check on our own? We do not have any special technical equipment, but are able to follow instructions from repair manuals etc.
    Here is what the KitchenAid repair manual instructs regarding these errors:
    F2 E0 KEYPAD DISCONNECTED
    Keypad E1 STUCK OR SHORTED KEY
    PROCEDURE: Before proceeding, press OFF, OFF, START to enter
    the Diagnostic mode and verify the error codes.
    A. Unplug oven or disconnect power.
    B. Check keypad connector for firm connection.
    C. Replace all parts and panels before operating.
    D. Plug in range or reconnect power.
    E. If error code returns after 60 seconds proceed to step F.
    F. Unplug oven or disconnect power.
    G. Replace keypad.
    H. Replace all parts and panels before operating.
    I. Plug in oven or reconnect power. Wait 60 seconds.
    J. If error code returns after 60 seconds, proceed to step K.
    K. Unplug oven or disconnect power.
    L. Replace cable connecting user interface and keypad.
    M. Replace all parts and panels before operating.
    N. Plug in oven or reconnect power. Wait 60 seconds.
    O. If error code returns after 60 seconds, proceed to step P.
    P. Unplug oven or disconnect power.
    Q. Replace oven user interface.
    R. Replace all parts and panels before operating.
    S. Plug in oven or reconnect power. Wait 60 seconds.
    T. Verify operation is normal. Press OFF, OFF, START to reenter the Diagnostic
    mode and complete checks.
    Line G recommends replacing the "keypad" (Is that an available part? Sears has a part #9756595ES that they call a "Switch" but no picture available for $155)
    then Line L recommends replacing the "CABLE connecting the user interface and keypad" (What is this part?)
    finally, Line Q rec replacing "USER INTERFACE" (Is that what you refer to as the control board? Sears has part # 4448871 for $191)
    I hate to buy all these parts unless I am pretty sure we are on the right track!
  • kgschultz6 Jun 11, 2011
    Well, we replaced the user interface/control board. We still have a problem...when I turn on either oven, it starts up. It heats for 1-2 minutes then shuts down (F2 E0 code). If we cancel then start again, the ovens continue heating, but each time only for 1-2 min then error/shut down. Eventually, repeating this cycle, they will heat to over 400 degrees. Same with broiler setting. Same with top and bottom oven. Any ideas?
  • 4,323 Answers
Hi
Error F2-E0 means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board and replace that if bad. Hope this helps...please post back for further assistance.
Daniel
Posted on May 28, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 28, 2011
    The only equipment that you need is a multimeter to check the oven temp sensor. If that is fine then it is the control board that should be replaced.
  • Daniel Scott
    You are right.....I wanted you to test the sensor before replacing that part....the part no you gave me is the correct one available at sears
  • Daniel Scott
    Daniel Scott Jun 11, 2011
    Thats why the first thing that I told you was to check the oven temp sensor before replacing any part
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Aug 07, 2008 | KitchenAid Architect Series KEBC107KSS...
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
111 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
