Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
How to check the heater element how much voltage should there be to it
  • 7 more comments
  • gasshydro May 28, 2011
    yes i have contnuity the voltage at the element when dishwasher is running is only 33 volts is this correct
    Daniel are you kidding me HOW MUCH VOLTAGE IS THERE SUPPOSED TO BE AT HEATER ELEMENT!!!
    the issue is that iam trying to see why the heater does not get hot
    how much voltage is there supposed to be to heater element
    thank you I checked voltage at the two wires to the element with the element unpluged I only had 33 volts is this the right way to check
    I checked on the two wires to the heater with the wires unplugged from the heater and only had 33 volts sounds like i should have 120 volts is this correct?
    ok thank you very much This dishwasher just wont clean alot of white residue using the same soap same amount could a restircked drain hose cause this?
    thanks again this looks like it will help
  • Whirlpool Master
  • 2,605 Answers
Hello, welcome to FixYa.
If you check voltage to the heater you should find 120vac. This can be done with an ammeter as well for amperage draw placed on L1 in the junction box at the bottom of the dishwasher...you need only to remove the lower toe panel/kick plate.
If the heater is drawing amperage it is obviously O.K. The quickest and most effective way to do this is starting a diagnostic cycle. (I should mention if the heating circuit was open the "clean" light on the control panel would flash until resolved)
To do so is (should be) as follows...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete, if you let it proceed through to completion or you can push "cancel" after checking amperage for the heater...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 28, 2011
  • 3 more comments
  • Mark MacDonald
    Mark MacDonald May 28, 2011
    Hello again,
    Thanks for the reply. If you check to just one lead and the other lead from your meter to chassis you should have 120vac when the heater is energized.
    If you measure across the heater when connected AND energized you should see 0vac. If you see 120vac across the heater when energized, you have an open heater, thus an open circuit showing 120vac across.
    Macmarkus :)
  • Mark MacDonald
    HI,
    I want to be sure I don't mis-guide you here, but the only time you'll have 120vac is when the control is telling the heater to come on, with one meter lead to chassis and one to heater wire. If the dishwasher is sitting there idle even with 120 to the machine there won't be 120 to the heater.
    As long as the test you are reading are gathered while the unit is running AND the heater is supposed to be on, it is conceivable you would see a low voltage reading such as the 33vac.
    If you try a voltage reading following the guide I explained in my initial post it should eliminate any doubt.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Based on your description, this is actually associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
    To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
    1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
    2 ) Spray arm removal. hold the center nut and spin the arm.
    3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
    a ) lift to depress the rear tab, i.e.
    b ) Then twist the feeder to the right ( clockwise ), i.e.
    4 ) Now you can remove the center nut...
    Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
    Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
    1) screw location
    2) tab to pull up on
    3) the latch you may need to twist to the left to remove the cover
    i.e.
    Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part. Make sure there is no debris present where I've indicated here with the arrow below.
    If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
    http://www.youtube.com/watch?v=iRCCrEwrs...
    Once these actions have been performed you'll need to press the following buttons in this sequence...
    This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again,
    I sure hope it helps, 95% of the time this is the solution. If you are satisfied please remember to take a moment to rate my assistance and accept this here today.
    Thank you again for choosing FixYa. Have a great weekend.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald May 29, 2011
    Hello again,
    I thought I'd do a follow up on your progress to see what you found, it's just something I like to do when I don't hear back from someone who posted a question and not yet rated my solution or replied to my last post.
    If the solution I presented did indeed solve your problem please take a moment to rate the assistance I provided or if it did not, let me know and i'll be glad to follow through with you to a resolution.
    Regards,
    Macmarkus :)
  • 4,323 Answers
Hi
Please check this video, it tells you how to check the heating element:
Hope this helps...please post back for further assistance.
Daniel
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 28, 2011
    Yes but what is the issue
  • Daniel Scott
    mso-fareast-font-family:"Times New Roman";color:black;mso-ansi-language:EN-US;
    mso-fareast-language:EN-US;mso-bidi-language:AR-SA">OK....thanks for rejecting
    the solution....I was trying to help you.....You
    should measure around 22 ohms of resistance. If you measure infinite resistance
    (open), then the heating element will need to be replaced.
  • Daniel Scott
    If you check the video ( free video) it tells you the "RIGHT WAY" to test the element.
One of the heating elements doesn't work
Might be. Only putting a multimeter will confirm this.
1st check for voltage. Is there voltage at that element? Then check for amperage draw? If proper voltage is present, and No current draw, bad element. If no voltage is present, you will not get a current/amperage draw, therefore the element is not necessarily bad. Check for reasons the element is not getting voltage. Bad Contactor is most likely reason when the latter is the problem.
Dec 21, 2013 | Saunacore Ultimate 5Kw 250 Cubic Ft Home...
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
We had no hot water so we check the elements with a voltage meter and found the bottom element to be bad. We replaced it. Now there is still no hot water. When we test the voltage again there is continuity...
The elements never run at the same time, it would take to much energy for a standard residential heater. Instead, they rotate powering up back and forth depending on the hot water demand. If you getting 208 to 240 volts on the top element and nothing is happening, the top element is bad and needs to be replaced. If you can swing 30 bucks, replace both elements and both thermostats at the same time. This way you know that everything is new. Check out this generic water-heater wiring schematic.
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
Does not work with electricity
Have you checked all breakers and switches are in on position, as well as the one on back side of water heater? If yes, shut off breaker to water heater, and pull cover at rear and check voltage carefully at element with power back on. If proper voltage at element, then replace element. If no voltage, check voltages at thermostat and eco on back as well.
Jul 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
KW9B model, power to unit but no heat when timer
Heaters are pretty simple: when timer is on, voltage is applied to the heater elements until timer turns off. To troubleshoot your problem, use a multimeter or circuit tester to check the terminal connections on the heating elements themselves. With the timer ON, you should be able to read voltage (120 or 240, depending on your heater) at those connections. If you don't check the continuity of the wiring from your timer to your heater. Continuity w/out voltage at the element indicates a faulty timer, no continuity means bad wiring. If you do read voltage at the element but it isn't heating, your element is burnt out -- time to replace it. If it's a newly assembled setup or seems odd to be burnt out for some other reason, double check that you're using the correct voltage for that particular heater... 120vac won't run a heater rated at 240vac.
Feb 04, 2010 | Saunacore Standard Residential Sauna...
Whirlpool RM280PXAQO power loss to one leg of bake element
remove leads from heater and carry out resistance test to see if heater is ok. you have checked the voltage so presume you have a meter.if not test voltage on both sides of heater connect directly to ground and other lead on ground of heater you should have a voltage if not you have a ground fault
Feb 18, 2009 | Microwave Ovens
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
388 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
