Question about Husqvarna 28cc Gas Line Trimmer
I need to replace the line cord on my Husqvarna Line Trimmer mod # 224L. Is there a diagram with instrucctions on how to do this?
  • Husqvarna Master
  • 1,807 Answers
I think you mean this
Posted on Aug 02, 2013
4 Suggested Answers
Tunneler
  • 27 Answers
SOURCE: I LOST THE MANUAL TO HUSQVARNA 128L TRIMMER HOW
Here's the link to the manual: Husqvarna 128l Manual
Posted on Aug 24, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
hunter19_46m
  • 7482 Answers
SOURCE: fuel line diagram My trimmer only runs for 2
Check your fuel filter in the fuel tank, if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Jan 26, 2011
Testimonial: "Thanks for the info. I will try this weekend."
Low power, runs rough, hard to start.
replace the fuel lines,ethanol kills them,then they leak air
Jul 04, 2015 | Husqvarna 224l Gas Powered Line Trimmer, 4...
How much oil does a husqvarna 224l use
The manual does not call for a specific volume of oil. Make sure to check the level using the dip stick and make sure the oil level is approximately half way up the dip stick. If oil is needed, SAE10W40 is recommended.
Sep 01, 2014 | Husqvarna 224l Gas Powered Line Trimmer, 4...
How to change cutting head on 224l trimmer
www.husqvarna.com/asia/support/contact-husqvarna
1 (800) 487-5951
Jun 17, 2014 | husqvarna"" ls 2 cycle oil"
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Need fuel line diagram for Husqvarna 322L trimmer
There are only 2 ways the pipes can go on. there is a fuel tank out pipe and a breather/return pipe.
Jul 04, 2012 | Husqvarna Garden
My new husqavarna 224l starts does not reach full throtle loses power regains power then loses all and dies whats the problem
Sounds like a fuel starvation problem, Check fuel lines, filter and primer bulb, also carb may need cleaning or new diaphrams
May 07, 2012 | Husqvarna 28cc Gas Line Trimmer
Just bought a brand new Husqvarna 224L Trimmer. Started it up and it runs fine. But the trimmer head will not turn. It just makes a grinding noise. The manual that came with the trimmer is useless. It says...
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Jul 21, 2011 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
291 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
