Question about Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I cannot see the entire picture even with Full Pixel setting. Only with the side by side PIP can I see the entire screen. I already reset the tv
    Top Expert:
  • Sony Master
  • 74,136 Answers
Hello
You can use the 'Wide Mode" function of the TV to adjust 4:3 image to fit the entire screen.
Press the "wide" button on the remote control repeatedly to step through Wide Mode settings WIDE:ZOOM:NORMAL:FULL, and ZOOM.
The "wide mode" settings are also accessable in screen settings too.
To do this, surf through the Menu, come to Screen:TV page. You can select all modes there according to your viewing taste.
Wide Zoom: Fills the screen with minimum distortion.
Normal: Select display 4:3 picture in original size when the original source is 4:3.
Full: Select to enlarge the picture horizontally to fill the screen when the original source is 4:3 (standard definition source). When the original source is 16:9 9high definition source), select this mode to display 16:9 picture in its original size.
Zoom: Select to enlarge the original picture without distorting the aspect ratio.
NORMAL IS NOT AVAILABLE WHEN YOU ARE WATCHING A 720p, 1080p or 1080i SOURCE.OK
Posted on May 28, 2011
  • The Knight
    The Knight May 28, 2011
    If you want to exit PIP mode Press "Tools" button on the remote control Press UP/DOWN button to hilight "Exit PIP" and press (+) button to exit. You may also press "Return" to exit PIP mode.
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
How to work pip in vizio tv
PIP or picture in picture works in two ways with the original remote--new sets with this actually have two tuners in them, one for main picture and one for PIP picture, you can change channels in both, swap the PIP to the main picture or even have both side by side.
Sure its got the PIP? what is brand and model number ?
Oct 30, 2012 | Televison & Video
Screen is completely black except for about 4 inches on top......
Try a reset of the display device or hit the menu button to get a display on the screen- If you get a full picture that way then you have some setting set wrong. It could also be a PIP- picture in picture mode that you only have one source put into the TV rather than two.
Aug 10, 2012 | Vizio SV320XVT 32 in. TV
Zoomed out Picture
button 19
ASPECT Cycles through Wide mode settings:
NORMAL/FULL/WIDE/ZOOM.
PIP Turns PIP/POP on and off.
Mar 25, 2010 | Polaroid FLM-2632 Television
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
53UDX10B
Good Day, peterferd;
Try resetting the TV by unplugging from A/C outlet wait 3 to 5 minutes then plug back in. No fix? Call service company.
Good Luck, big IRISH.
Apr 16, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Only picture in picture works
Your pip module has went south.The capicitators on the board have leaked and ruined the board.Agood tv repair man can bypass the module to get you a full screen picture again.The only problem is you will no longer have pip ability.
Mar 07, 2008 | Sony KP-48S75 48" Rear Projection...
I can not get picture in picture off screen
if your sony don't have pip buttn. that tells your sony don't have pip board installed , i am afraid the pip comes out of the source you are getting the video signal sometimes your sat dvb dvd have pip in its menu check it out plz regards
May 02, 2007 | Sony KV-32S26 32" TV
Sony BRAVIA KDL-52S4100 52 in. HDTV LCD Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
