The DS22 is nothing more than a data cable with a case around one of its end plus a simple set of extra connectors - no electronics whatsoever.
If the dock is detected as unconnected then either the cable that it uses to connect to the main unit has broken a wire internally or the connector itself (the one to the device) has one of the pins detached. Since both defects are unfixable - the cable can't be spliced to repair the breakage and the pins can't be resoldered - it means that the dock is dead and you will have to buy a new one.
Luckily it's not a very expensive item, it won't cost you much to replace it.
