Question about Mr. Coffee JWX27 12-Cup Coffee Maker
My coffee makers digital screen is not seen. Cannot set time or turn on coffee maker. Checked outlets all fine. Just purchased. Only used a few times.
  • 6,771 Answers
The coffee maker has clearly a manufacturing flaw, from your description the thermal fuse has opened and is welded to the heating element. The only option is return the unit to the place of purchase.
Posted on May 28, 2011
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Apr 28, 2014 | Mr. Coffee GBX23
Machine will not turn on. Worked fine 12 hours ago
Have you checked for power at the outlet?or maybe try and unplug for few minutes and plug back in to outlet or another outlet...also outlet maybe gfci protected,look for reset button on outlet or in main breaker panel.
Jul 26, 2011 | Keurig Elite B40 Coffee Maker
Keurig coffee machine model B77 coffee maker will not turn on
Mine will not either. Yesterday it worked just fine now it's as if it is not plugged in. I checked the outlet, it's not that.
Jul 28, 2010 | Keurig B70 Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
Coffee maker is about 2.5 years old. Has worked fine until...
does it have two switches? mine does and if the main is off, the other is off.
Sep 18, 2009 | Cuisinart DCC-2000
Why is my coffee maker not working
I will assume the outlet is working and there is no timer that is set to turn the coffee maker on later. There are a few possibilities 1- the switch is defective 2 - there is a temperature sensor in contact with the heating element that is defective 3- the element itself is defective. these parts are all internal and may not be easily accessible without proper tools. All the components can be checked with an ohm meter. Also check for loose or broken wiring connections.
Mar 11, 2009 | GE 106591 Coffee Maker
Brewstation
There is a very fine screen on the outlet of the carafe that becomes plugged over time with fine coffee grounds. You can see it if you look down inside the pot above where the coffee comes out. Just using coffee pot cleaner won't clean it, because it's fine coffee grounds stuck in the screen, that are slowing the coffee going through it.
It's not easy to reach, so you'll a pair of needle nose pliers. Get ahold of the plastic ridge the runs across the top of it and it pops right out. You can use the bristles of an old toothbrush to scrub it. The bristles will fit in the spaces of the fine screen and force the deposits out. You can probably just leave the screen out altogether, it's just there to stop grounds.
Feb 14, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Mr. Coffee JWX27 12-Cup Coffee Maker Logo
131 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
