Question about Seth Thomas Radio-Controlled Howard Wall Clock - SET717
I need help setting the alarm on my radio controlled digital clock.
  • 1,116 Answers
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • Posted on May 28, 2011
    Cannot set time
    WWVB Radio Controlled Clocks
    www.nist.gov/.../radioclo...
    National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
    [PDF]FM/AM Clock Radio - Sony
    https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
    [PDF]Atomic Analog Wall Clock - La Crosse Technology
    https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
    clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
    ICF-218 Sony Alarm Clock - YouTube
    ? 1:50
    https://www.youtube.com/watch?v=XTQ8zEMMNq8
    Aug 4, 2012 - Uploaded by sohvintage
    Jan 10, 2016 | Audio Players & Recorders
    I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
    PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
    www.conair.com/instruction.../07ps111_su7_ib.pdf
    Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
    Muse - Alarm clock radio
    www.muse-europe.com/en/products/alarm-clock-radio
    Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
    Jan 10, 2016 | Watches
    The time does not automatically set on my sony alarm clock XDRC706DBP
    Afraid I have the same problem and I have to manually set.
    good luck !
    Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
    Alarm
    If your clock radio is like mine here is how it works:
    Hold down the "Alarm Set Off/On."
    While holding this button down, press on the "Hour" button until you get the time you want to wake up. Set the minutes the same way. Be careful- look at the red light to the left of the digital time to make sure it is lit up next to the " AM" spot just to the left (not digital, but usually on the radio metal or plastic itself.
    Then let go of these buttons. Go to the right-hand side and slide the button to show if you want to be wakened by the radio or a buzzer. If you want to keep on that schedule, you don't need to do anything. Just move the button to "Off" the night before a day off so you can finally sleep in!
    Hope this helps.
    May 12, 2014 | SkyScan 34202 Clock Radio
    I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
    To set the clock:
    1. With the power off, press the TIME button; the time will blink.
    2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
    Make sure to set the correct AM/PM setting.
    3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
    To set or reset alarm time:
    1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
    Press the MINUTE button to set the alarm.
    2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
    Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
    to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
    3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
    If you needed the manual it could be downloaded:
    http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
    Thanks.
    gylacz
    Aug 01, 2011 | Memorex MC7101 Clock Radio
    Instructions to 'science museum' radio controlled alarm clock
    press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
    it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
    Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
    How do I set the alarm? Please help! Am I supposed to do something after setting the time of the alarm? The display continues to flash the time.
    To set your alarm you should be turning your Set Control (the big round button just below the Set Day button) to Alarm 1 or 2. Once you finish setting your time you should be able to turn the Set Control back to Clock and the time should stop flashing. If this does not work you may have a defective unit which you might have to take up with your retailer.
    Jul 07, 2009 | Philips AJ3965 Clock Radio
    Need instructions
    I found the manual for you at http://www.timexaudio.com/pdf/T300IB57134_31.pdf
    You cand find the manuals for all Timex Clock/Radio conbinations at:
    http://www.timexaudio.com/product_manuals.asp
    Go Get 'Em
    FixedThemAll.......
    Sep 28, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
    Alarm clock won't change time with daylight savings
    unless it is an automatic , atomic clock none I have ever owned do the change automatically
    Feb 27, 2017 | RCA Audio Players & Recorders
    Clock settings
    - Please let us know the make and model number so that we can try to find the user manual for you. -
    Oct 02, 2007 | Panasonic RC-6299 Clock Radio
    Seth Thomas Radio-Controlled Howard Wall Clock - SET717 Logo
    804 people viewed this question
    Top Seth Thomas Audio Players & Recorders Experts
    Dennis Key
    Dennis Key
    Vito Vacirca Jr.
    Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
