Question about Cameras
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a video!!!!!!
  • damneddle
    damneddle May 28, 2011
    Are you sure your SD card is not full?
  • Cameras Master
  • 6,771 Answers
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
Posted on May 28, 2011
  • morton508
    morton508 Aug 10, 2012
    Great advice John. This resolved my problem. Other people telling me to buy a new memory card. Thanks
  • John Cunningham Aug 10, 2012
    Thank you, that is wonderful news.
  • Cameras Master
  • 17,970 Answers
When your internal memory is full it means that you have taken an amount of pictures that has filled up the memory of the camera. You will want to buy a memory card (such as this) to store the pictures you take on your digital camera
Posted on Jun 01, 2011
Vivitar camera isnt reading sd card
What type and size memory card? Is it formatted?
Dec 22, 2012 | Vivitar Dvr-410 - Camcorder - 1.3 Mpix -...
Not formating
hi my pny premium sd card wont work in my vivitar dvr 410
Aug 06, 2012 | Electronics - Others
Vivitar 410v3, memory full, Please insertan SD memory card, but the SD is empty, i dont know why working
might be disprogramed the whole camera and does not regonice the chip and the camera
Apr 17, 2012 | Vivitar Cameras
Have new Vivitar DVR810HD Digital Video Camcorder, loaded SD card correctly but camera does not record onto SD card Help!
Make sure that the video camcorder was not turned off immediately after recording before the images are saved in memory. Also be sure that your memory card is properly inserted in your camera.
Feb 27, 2011 | Vivitar DVR 810HD Flash Media Camcorder
Do i need a sd card to operate my vivitar 410
Yes you do. The Vivitar DVR 410 requires a standard SD memory card (up to 16GB) to record images or video. The 410 is NOT designed to accept SDHC memory cards so make sure you purchase the proper type.
Jan 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
My vivitar 410 is saying the memory is full but it has a brand new sd card???
Hi
There are two Vivitar DVR-410 models. A model released in the early 2000's and a newer version released in 2010.
If you have the the earlier DVR-410 model then it will probably only use low capacity SD cards - e.g. 512Mb or lower. if you are trying to use a higher capacity card on this model it may well show that it is full.
If you have the modern 2010 version of the DVR-410 then it can uses SD cards upto 2Gb and SDHC cards upto 16Gb
You should also check the card you are trying to use is formatted, and the lock switch is not set.
Hope this helps
David
Dec 29, 2010 | Vivitar Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I just inserted 4GB Memory card and took only one picture. I keep getting error message "Memory card is full, insert a SD Memory Card to Transfer and take more photos".
http://www.vivitar.com/products/19/ViviCam%205018%20User%20Manual.pdf
Is the manual, and you need to refer to pages 6 and 7.
If you still have problems, you should contact Vivitar support. This should not be a problem since the camera automatically switches to the SD card when inserted.
Jan 10, 2010 | Vivitar ViviCam 5018 Digital Camera
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Open Questions:
Cameras Logo
545 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
