Question about HP Pavilion a305w (DM181AR) PC Desktop
My girlfriends Hp Pavilion A305W powers on then automatically powers off after it show a brief error message but also says F1 for startup. Should i press F1 and continue diagnosis?
    President:
  • 2,340 Answers
Most probably your system is not getting your BIOS settings from your mainboard due to CMOS battery failure.
Check your CMOS 3.0v battery & replace it. Then reconfigure your BIOS settings from the CMOS setup.
Hope it helps
Posted on May 28, 2011
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
Can an HP Pavilion a305w imperial GL_VE 20021218 137001 motherboard with a celeron 2.7 ghz 400 mhz intel processor be upgraded to a pentium 4 2.66 ghz 533 mhz processor?
Yes as long as it is the same case stile and 400 mhz.
Base processor Intel Celeron 2.7 GHz
  • 400 MHz Front side bus
  • Socket mPGA478
    Note.... Make sure you use PC2700 memory PC2100 will give you error messages
May 22, 2014 | Intel Computers & Internet
My hp pavilion a305w would start up but no lights changed power pack but now i dont know what wires go where since i didnt write down where they went can u help me?
Power supply plug goes in the plug on the motherboard, that is the big plug. There wil be one 4 pin plug that goes to the hard drive and one to the DVD drive. There will be some extra plugs for future hardware installs
Mar 19, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
Was just wondering because i tried one method but didn't work for me on my hp pavilion a305w, but my question is, can hp pavilion a305w boot from usbs?
unfortunately the hp pavillion a305w bios would have to support it. you would have to go into the bios on set uo and select that boot option. but unfortunately they do not have the option to boot from usb
Jan 08, 2011 | Computers & Internet
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    HP computer doesn't turn on
    Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
    Dec 12, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Hp pavilion a305w isnt working
    sounds like it is in standby mode..........try pressing and holding the power button until it turns off fully. then remove the power cable to reset the power supply, wait for 5 mins then plug in and try again,
    it is also possible that you have a fault , possibly a failed power supply, it might be best to investigate that if the power reset doesn't work
    Sep 17, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    HP Pavilion a305w (DM181AR) PC Desktop Logo
    117 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
