Question about Jandy Ae2500t 115,000 Btu Heat Pump
I have a 4yr old AE2500T and the temp. read out is in Celsius. the set point temp. is in Fahrenheit. How can I change this so they are both in Fahrenheit?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Go into setup you can change there
Posted on Sep 25, 2014
How to switch temp. readings from celsius to degrees?
Celsius IS a temperature measured in degrees, as is Fahrenheit.
I don't know about your rig, but my guess is that you can hold down the menu button or go to "set up". Get the temp to flash, push the up/down button until the change. If you are needing to make a manual calculation, Celsius is changed to Fahrenheit by multiplying the reading X9, dividing that by 5, and adding 32 to that number.
Ex== 30 degrees C to F is 30X9/5+32= 86 degrees.
Oct 19, 2014 | 2015 Jeep Wrangler
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
Subzero 850 freezer temp reads minus 20 degrees
Is it possible your unit is set to celsius rather than fahrenheit? I ran the -20c though a converter and is this is true your unit is running at -4 degrees fahrenheit and this would be a little cold but ok at this temperature. I would personally check settings before going further in to any repair. I was reaching the model you gave me and found the number you gave was incorrect. But try this; turn the whole unit off for a couple of minutes. Turn it back on, then push and hold the alarm and unit power button for 5 sec. this can only be done within the first 5 minutes of power up. This should confirm your display setting is correct, I am assuming you want fahrenheit rather then celsius. If this doesn't work for you, I will need to confirm model number so I can send you a digital version of the service manual if you need it.
Good Luck
Oct 15, 2011 | Sub-Zero 650 / O Bottom Freezer...
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
How to change celceuis to fahrenheit ?
Convert Fahrenheit to Celsius
Tc = (5/9)*(Tf-32)
Convert Celsius to Fahrenheit
Tf = (9/5)*Tc+32
where Tc is Temp in Celsius and Tf is temp in fahrenheit
Aug 18, 2010 | Hyundai Motor 2004 Sonata
Change from celsius to fahrenheit
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
In order to change the temp setting from C to F, Press cancel & bake together for 5 seconds then use the more or less pads to change.
Nov 20, 2008 | Maytag MER5752BAS Stainless Steel Electric...
Jandy Ae2500t 115,000 Btu Heat Pump Logo
136 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
