Question about Kenmore 22422 Top Load Washer
Modle 80 washer question?
My washer has just started to stop everything motor related. In the correct timer position, the washer will fill. But after the motor runs for a very short time it will just stop. If I let it unplugged for a while it will then run again for a short time, then stop again. When this happens I hear a "click". The motor sounds ok? Is there a thermister or any kind of heat related reley? If the timer motor is bad? Can it still fill, but not run the motor or should I say cut the motor operation off?
    Genius:
  • 1,028 Answers
Ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Posted on Aug 17, 2008
2 Suggested Answers
SOURCE:
  • 261 Answers
SOURCE: Modle 80 washer.
If in spin the water drains ok then your coupler is faulted, If not the motor is faulted.
Posted on Aug 28, 2008
Trying to install timer on Maytag coin-op washer. Did something wrong It filled with water and then stopped
Check voltage supply to the timer, make sure power is still supplying
the timer motor when the water shuts off, at which time if the timer motor is powered will close the next set of contacts and start the wash
cycle. Make sure you have the correct timer.
Also check the safety switch for the lid, if the lid does not close that switch or if its bad, the wash cycle will not start.
Oct 23, 2012 | Washing Machines
My washer has filled up with water and then just stopped and wont begin the cycle...
Try manually advancing timer . If washer starts , timer motor is bad or gets stuck , or water level switch is bad and not sending power to timer.
If washer doesn't start ,the lid switch is stuck not sending power to timer or god forbid, timer is shot.
In some models , lid switch controls everything which may be your problem .Try manually operating lid switch or jumping it with jumper wire.Or just replacing. Its' the easiest to fix and most likely problem.
Good luck
Aug 15, 2011 | Maytag PAV2300 Top Load Washer
LAT5000AAW, power is on but the timer is not ticking. Apearantly after filling the washer with water going through 2/3 of the cycle the timer must have quick. I checked that all the swithes, and checking...
if that's filled with water and stopped a common problem with this washer was the lid switch part WP22001682 you can't get the timer for this washer anymore,unplug it,open up the top console and check the lid switch.
Dec 21, 2017 | Maytag Washing Machines
The washer will fill up with water but it wont start washing or drain or spin you hear a humming noise then everything stops. Then in about 5 mins it will hum again then stop again
If the washer will not agitate, spin or drain it's a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction. The reversal of the polarity is controlled by timer contacts 7 and 14.
Most likely it's a timer or loose wire connection.
Jan 22, 2011 | Estate ETW4400VQ Top Load Washer
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Modle 80 washer.
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 22422 Top Load Washer Logo
62 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
