Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Color shifting My set works fine for a while, then the color beging to shift, change, and go monochrome, then back to color. It happens with digital cable, as well as DVD play.
Need to know model number to help more.
If it is a DLP sounds like light/optical engine.
by shift do you mean it looks 3D like colors are separating, or losing color?
Posted on Aug 21, 2008
    Scholar:
  • 167 Answers
Hello sound's like you have a convergernce problem to me . !!! need's to be replaced. a"good luck"
Posted on Aug 20, 2008
Hi, I have a 98 Windstar that recently began having transmission problems. When we first drive it starts out fine but once we've driven several miles it will get stuck in 2nd gear.
The switches inside need to be replaced they are hanging up do this now before you ruin the clutches it will go back to normal shifting and work fine change all pressure torque lockup and shift switches diy for about 125.00 with fluid filter cost and back to normal shifting and a happy van and crew make sure vans not running hot burning fluid otherwise will happen again high temp burned fluid damages switches ability to work
Sep 04, 2017 | 2001 Ford Windstar
1999 dodge ram 1500 5.2 liter, auto, 2 wheel Trans ran perfectly ...then stopped shifting from second to third. wouldn't change gears, even manually. i checked all connections into trans, checked trans...
1999 dodge 1500 5.2 will not shift to second once the engine reaches normal temperture or I shift from drive to nutural and back to drive then it will work fine untill the next time I stop. filter, fluid, shift slenoid,governor sensor have been replaced.
Jul 13, 2010 | 1999 Dodge Ram
I have to rev the engine up more than usual to get the car to move in drive or reverse. Once I'm moving the car shifts out through all the gears fine. As I'm slowing down to a stop, and can feel the car...
Did you empty the torque converter also? If not you have not changed out all the fluid, now it will be diluted by old fluid. It can be a modulator but it will need to be tested by a transmission tech to know for sure.
May 14, 2010 | Chevrolet Cavalier Cars & Trucks
Transmission promblem
Assuming you have an automatic transmission, I would check the transmission fluid level. If low, you need to identify where the fluid is leaking. Probable locations are transmission pan, or the cooler lines to the radiator.
If this has only begun to happen your transmission will probably be ok. If it has been happening for a while then you will probably be looking for a new transmission.
There is also one other possibility. If the check engine light is on and the codes read something in the area of "transmission control solenoid" or "shift solenoid" then you will need to have those replaced.
Mar 11, 2010 | 1996 Chevrolet K1500
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
My picture keeps changing colors and images are shifting around on the screen. Example is say there is a person on theTV picture, well it will glitch and move part of his face to to oppostie side of the...
Do you hear any strange noises when the color is shifting? If so then the possibility is the color wheel is failing. The color wheel failing after a few years is not so uncommon. The unfortunate part is you would need RCA part number 212184 for the color wheel and it is no longer available. The complete light engine is the only thing that appears to be available and that part number is 261589. I would have a technician look at the TV to verify my findings. Please take a few moments to rate my answer. Thank you...
Nov 17, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Color shift to green on non hd channels
change out your box. thats why they rent them. they anticipate your going to have issues thats why they rent them. i have gone through about 12 boxes over 5 years. change res to 1080i
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Transmission not shifting when dash lights and spedio not working
I had a similar problem on a Ford Taraus. The car wouldn't shift when the speedo wasn't working. When the speedo decided to work then the transmission shifted fine. The problem and Fix it I found was because the Speed Odometer Sensor on the Transmission wasn't working so the computer was flying blind as to how fast the car was moving (not knowing when to shift) and therefore the computer placed the transmission into a "Safe Mode." When I realized what was happening I changed out the sensor and the car has never shifted so fine.
Good Luck!
Mar 29, 2009 | 1994 Chrysler Concorde
Color off seems amber
Double check the wb settings in camera, (and be sure to check WB Shift) I'd suggest adding a Blue shift to your images to compensate for the Amber until you find something thats a decent trade off, if you can't eliminate the amber shift.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Digimax 240
Check the color/light settings on your camera, and reset it to auto to get it back to normal. Changing this setting to tungsten or fluorescent forces your color to shift, but is clearly not what you want at this point.
Jun 05, 2008 | Cameras
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
