My Ott Lite won't turn on. The bulb is new. The clicker switch on the cord clicks but nothing happens. Is this something that can be fixed or is the Ott lite ready for the trash?
msgetlost
SOURCE: ds lite charging lite comes on but when i press power button nothing happens
i left to go to the mall one day and there were a whole bunch of little kids here and i put mi ds on the back of my sofa and wen i came back my ds didnt come on so i charged it for 3 days strait and on the charge button will come on but when it does it stays on for like 2 minutes then cuts of and mii game doesnt come on and the kid didnt do anything but play with it
Posted on May 24, 2009
  • 6 Answers
SOURCE: Turn signal clicker clicks when I press on the brake pedal
change the relay
Posted on Jun 27, 2009
ddinneb
  • 211 Answers
SOURCE: removal of burnt out bulb in ott lite
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
Posted on Jan 28, 2011
  • 116 Answers
SOURCE: 2007 chevy cobalt ls won't
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Posted on Jun 06, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
My brand new ott lite will not turn off. what am I doing wrong
Get in touch with Ott Lite at: http://www.ottlite.com/t-customerservice.aspx
May 08, 2015 | Ott lite Ottlite 759803 Task Lamp Blue
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
My left turn signals don't work.you can hear the clicker working normal and the courning lite come on. If you leave the signal switch on the turn lite will flash once in a while and also the lite on...
You most likely have a bad bulb, if the front bulb goes the rear wont work and vise versa both bulbs must be good to complete the cirrcut. Even though you have no lights you should still hear the flasher relay. Bulbs are cheap just replace both and you'll be good to go. Good luck
Aug 18, 2011 | 2001 Buick Park Avenue
Removal of burnt out bulb in ott lite
Douglas
Sep 12, 2010 | Ott Light OttLite Truecolor Table Lamp
857 people viewed this question
k24674
jasbo
jasbo
