Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hi I have a hoover steamvac deluxe se. I am having trouble attaching the upholstery attachment to the front of the water tank. It gets stuck and I can't push it all the way down.
3 Suggested Answers
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Dec 06, 2007
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How do you change from tool attachments to floor?
On the front of the recovery tank is a slide-out piece. lift up and out (or down-depending on your model). On the end of the hose is a piece the same size and shape as the one on the tank. Slide it down in the slot in the recovery tank. You'll see a little push door labeled
"upholstery and floor attachment". Push down on the top of the door to open it. Then take the hose attached to the piece inserted in the recovery tank and push it into the upholstery and floor access door.
May 15, 2012 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How do you attach upholstery hose
The upholstery hose attaches to the front of the recovery (lower) tank. There is a square plastic duct which must be removed, or folded forward on recent models; and the end of the hose slides into the front of the tank. Be sure to replace the lid on the dirty water tank correctly. The connector on the soap tube attaches to the valve under the trap door on top of the nozzle.
Jan 22, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Superscub attachments won't work
It sounds to me like you have the water hose plugged in, but not the hose block. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. If you have already done this, then here is your problem: when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" your tank is now ready to pick up the dirty water from your hose. let me know if this helps!
Aug 06, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
The water won't stay in the tank...
you will have to replace the complete water tank assy. i have tried without any luck to get this valve to stay in place.
Oct 01, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Jan 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
