My split air conditioner compressor fail is it due shot pipe length total pipe length less then 1.5 mt.unit is 1.5 Tr and room size is 160 sq ft.using steblizer.
  • 1,056 Answers
A/C compressors fail because the system is overcharged, not enough charge in the system. Compressor can also fail if it's started before it has a chance to cool down first.
Posted on May 28, 2011
How to figure 12x12 sq ft
12 x12 = 144 sq ft
12 x12 x12 = 1728 cubic ft
May 02, 2015 | Heating & Cooling
A build-up of ice on my air conditioner behind the filter which is room size
Check air filter and check the access water drainage pipe for any conjuction
Nov 09, 2012 | Haier Hwf05xcj Window 5000 Btu Air...
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
How do you calculate cfm for a room when sizing a hvac system fr a residential
their is a chart that homedepot use to give in a/c dept may still be their but a 6" run is about 100 cfm this will cover 10x10 1 sq inch is 1 cfm 1 ton is 400 cfm a gas system is 400 per ton and a heat pump is more like 425 but is best to figure the 400 cfm for both say you got 12x10 room that is 120 sq ft so you need around 120 cfm and if the 6" duct is 100% hard pipe with no flex you can get that if you balance your air if more help is needed email pendletonheatandair@hotmail.com please give me a vote and rating
Sep 22, 2010 | Cfm Heating & Cooling
Calculation of CFM discharge from an opening of a duct collar
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
Jun 20, 2009 | Carrier Heating & Cooling
Lingth of line
The length of line set can dramatically effect the efficiency and operation of the air conditioner. There is a science behind the design and application of the different sizes. Refrigerant carries oil in it as well as the refrigerant itself. The length can change the amount of oil that is supplied to the compressor. The length of pipe can change the indoor coil's ability to flash to vapor gases.
The instructions that came with your unit should be able to simplify this for you. There will be minimum and Maximum lengths and possibly even some graphs and tables to study.
Jun 30, 2008 | Fujitsu 24C1 Air Conditioner
Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Jan 06, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
