Question about Neptune Washing Machines
We have a Maytag stacked washer dryer. We had a lightning hit near the house yesterday and now the washer will not turn on. Somthing happens if I set it to spin and hold the start button in, though.
    President:
  • 2,468 Answers
Can you get the diagnostics sheet out of the machine its usually inside near the top and try to set-up the diagnostics to look for any error codes,if this is not possible,then it can be either the interface keypad board/the central control board (CCU)/or the motor control board(MCU) or all 3 boards depending on the severity of the hit,but for sure the control board where power enters the unit
Posted on May 28, 2011
Just bought a new (old) house and the Maytag stackable w/d stayed. The dryer doesn't heat up at all. We've cleared the vents, but still no heat.
Check that you have 220 volts. or see that the timer is not set to Air Fluff ( no Heat)
you may have a bad thermostat, or a broken
heater coil. or a broken belt.
May 26, 2010 | Maytag LSE7806A Top Load Stacked...
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
LSE7806A Top Load Stacked Washer / Dryer . Do you know where I could get a fuse for this?
Yes. Any appliance parts supply house, either locally or on-line.
Regards, --W/D--
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Stackable maytag washer and dryer
Hello, on most Maytag units you can take the the front panel off by removing 2 phillips screws , 1 on each side of the front panel. With the panel off you can run the machine and see where the water is coming from. Good luck
Dec 21, 2008 | Maytag LSE7806A Top Load Stacked...
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag drier model MDE5806AYW
hi thanks for the question i would guess the motor but man thats a hard one if the dryer was hit by lightning it could have caused a fef problems myself i would call my insurance company tell them you were hit before you call the insurance check all appliances in your house you may find other problems thanks the appliance doc
Jul 22, 2008 | Maytag PYE2300AY Electric Dryer
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
110 people viewed this question
Top Neptune Washing Machines Experts
Cleverer2
Terry Hair
ray gallant
Are you a Neptune Washing Machine Expert? Answer questions, earn points and help others
