Question about Hitachi 50DX20B 50" Rear Projection Television
NO COLOR ON MAIN TV
I HAVE A 50DX10B AND THE PICTURE ON THE MAIN SCREEN HAS NO COLOR BUT THE PICTURE ON THE PIP HAS COLOR.
CAN SOMEONE TELL ME HOW TO FIX THIS??
Do you want to sell the mirror?
Posted on Nov 10, 2008
I have a 50DX10B TV ,the red when you try to set it on digital array is pulled down in the top left corner ,the cross is flipped on its side,picture is pulled down across the top of screen,red color,double...
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 06, 2010 | Hitachi Televison & Video
Screen looks like a picture negative, PIP works fine, sound fine
Sony's have dual tuning systems to allow for the separate PIP channel. The common problem on the Sony's is the circuit board and tuning module connections go bad. It is likely that the connections on the board or module were already in the decayed process and moving it just accelerated the issues that were inevitable.
The quick fix is to swap the PIP over to the main picture or to bus the antennae signal to the antennae B terminal thus bypassing the bad tuner module.
The recommended fix action is to have someone with soldering skills to remove the chassis, and locate all the cold and cracked solder joints, especially near the tuning modules. If this does not take care of the problem, the tuning modules will need to be removed for re-soldering on the actual tuner modules.
If none of the above works, then you can always use the audio/video outputs of a cable box or vcr to the a/v jacks of the tv, thus bypassing both tuners in the tv.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Ilo problem
What I hear you saying is that your main television tuner shows lines only while the PIP is functioning properly. The PIP works by using a separate tuner from the main tuner of your television (like a vcr tuner). Since the PIP works then it appears that your main tv tuner is not working anymore. It will probably have to be replaced. I recommend looking at our online technician list for a professional near you.
Good luck :)
Jun 20, 2008 | iLO 3200 32 in. LCD Television
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Dec 04, 2007 | Mitsubishi VS-60611 60" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Foot note to issue
If the source to the PIP input is a color signal then the PIP display will be color. PIP sets have two video sources one goes to the main screen while the other goes to the PIP. it all depends on what the format of the signal is being sent to each input. This is quite normal.
Jun 29, 2007 | Mitsubishi VS-45607 45" Rear Projection...
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Hitachi 50DX20B 50" Rear Projection Television Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
