I have a 46inch samsung lcd model LE46M51 when switched on it flashes on for about 2 seconds then the screen goes blank, there is still power and sound.
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
wayez3
  • 20 Answers
SOURCE: NEC 19'' LCD monitor power on but screen blank
If you can try it on another unit , If it still does not work, Then the most likely culprit is a bad power supply. If you know any thing about soldering replace the capacitors they are probably bad but being that these things are being built so cheap.It could also have a bad inverter. not repairable by average dude.If you open it be careful and do not attempt unless you feel comfortable with a solder Iron.Hope this can help you Good Luck. www.IrionsTVshop.com board re builders.
Posted on Feb 29, 2008
SOURCE: HANNSPREE YT0837E2 37" LCD TV
Same problem.
Posted on May 05, 2008
SOURCE: SONY LCD GOES OFF
Try turning the tv off, then unplug the tv from the wall for at least 60secs. Plug it back in. Turn it on and see if the blinking has been reset to normal.
Posted on Jun 04, 2008
Pyrhyc
  • 2028 Answers
SOURCE: logik tv lcx27wn2 sound but no picture
the only info I could find on this is one withthe same problem. Replacingthe monitor had no effect and the store exchange it.
Posted on Jun 18, 2008
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Samsung 940mw monitor ringing then blank screen
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com Look on the monitor repair page 2. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 940MW 19 in. LCD...
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Swicthed on tv and its a blank screen..now it wont switch off.
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
lone99star
Jan 09, 2009 | Samsung Televison & Video
Picture for 1 second then screen goes blank but still have audio
i have taken the tv to repair shop a circut board has went on it
Dec 30, 2008 | JVC LT-32E479 LCD TV
Televison & Video Logo
Top Televison & Video Experts
