Question about Casablanca Fan 3245T Ceiling
Casablanca delta II model 14222 s/n et 02104 can get the fan to work but can not get the light to work. casablanca said all their fans are wired for lighting. the fan originally did not have the wiring set up for a light.
1beertap
  • 32 Answers
SOURCE: Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Posted on Jun 10, 2007
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
MN_Jack76
  • 45 Answers
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Posted on Feb 06, 2009
MN_Jack76
  • 45 Answers
SOURCE: Casablanca Ceiling Fan
I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
toolkits
  • 1099 Answers
SOURCE: Casablanca Delta II fan wobbles terribly at high
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
Posted on May 31, 2010
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    I need to know the wiring to a replacement switch for a ceeling fan no lights,Cassablanca Lady delta modle
    White wire is probably a wire you connect to a light kit, if you had one. Fan switch should have 4 wires. If it's not from Casablanca it's probably not the correct switch.
    Jun 14, 2015 | Dryers
    I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
    You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
    May 13, 2015 | Casablanca Fan Dryers
    Can't get Casablanca fan to work the wiring is
    What model do you have? This fan came with a special control and will only work with that control.
    Jun 16, 2013 | Dryers
    The fan button on my Casablanca inteletouch swich will not turn on the fan. The light button works but I have to use the power button to turn on the fan which then turns on both the light and the fan. I...
    There are two source wires coming out of that unit. One is for the fan the other is for the light. It appears from your descriptions that the issue is related to a wiring issue.
    Mar 07, 2018 | Casablanca Fan Panama II 50" Ceiling
    Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
    Good luck...
    May 31, 2010 | Casablanca Fan 3245T Ceiling
    We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red,...
    On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
    If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
    Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
    If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
    Also, please turn off the power before connecting the light kit to the fan.
    Hope that helps and best regards!
    Jul 31, 2009 | Casablanca Fan 4944D Concentra Antique...
    Casablance Ceiling Fan Trouble
    itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
    Jul 16, 2008 | Casablanca Fan 3245T Ceiling
    This is actually a Delta II model fan. The fan blades and the ring they are bolted to recently dropped out of the fan housing and are sitting on top of the base of the light kit. Is this the flywheel? If...
    it is the flywheel. I ordered one directly from the Casablanca web site, took the fan down and find the parts are pressed together. Looks like it needs some heavy tools or a jig of some kind. Any suggestions?
    Jul 05, 2008 | Casablanca Fan 3245T Ceiling
    Casablanca Fan 3245T Ceiling Logo
    206 people viewed this question
    Top Casablanca Fan Dryers Experts
    Jerry Greenberg
    Jerry Greenberg
    Paul Bade
    Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
