Question about Bissell 1716 Spot Lifter PowerBrush Bagless Handheld Vacuum
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
  • 276 Answers
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
Posted on Jun 01, 2011
Need instructions for use of Bissell Spotlifter
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 07, 2010 | Bissell SpotLifter 1716 Bagless Handheld...
I need a bissell spotlifter manual need bissel phone # have no e-mail
Or contact BISSELL Consumer Services at 1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 10, 2010 | Bissell SpotLifter 1716 Bagless Handheld...
I need to download an instruction manual for Bissel SpotLifter Power Brush, Model 1716
You can download the instruction manual by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 20, 2010 | Bissell SpotLifter 1716 Bagless Handheld...
I borrowed my friends Bissell model 1716 07218C. She doesn't remember how to use it and doesn't know where the instructions are. Thank you for any assistance you can give me on how to use this product.
http://www.bissell.com/Product_Search.aspx?Criteria=Spot+lifter
Go by the look of it (not the model number on here) to see which model it is and you can download a free pdf user manual copy.
Don't forget to rate, thanks.
Jul 21, 2009 | Bissell SpotLifter 1716 Bagless Handheld...
WIll not spray
I had the same problem. I took a small wire and pushed it through the nozzle from the front quite a ways in. When I plugged it up and tried it the solution came out great.
Sep 02, 2007 | Bissell SpotLifter 1716 Bagless Handheld...
Bissell 1716 Spot Lifter PowerBrush Bagless Handheld Vacuum Logo
232 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
