Question about Caroma Home
Toilet seat is loose! This is a quick release toilet seat with buttons on the sides. Once the seat has been removed I would like to tighten the plastic bolts but have been unsuccessful. Is there a special tool for this?
  • rstinchc May 28, 2011
    I only wish the solution were this simple. In this case there are no nuts on the underside of the toilet. I have never seen this set up before and that's why I wrote for help. The two plastic bolts have flat heads about the size of a quarter and there are no slots in them for a screwdriver. Also, the plastic heads of the bolts appear to be offset, something else I have never seen.
  • Nick Oct 21, 2012
    Ignore the other posts. Remove the seat by pushing in the small buttons at side of the hinge. Now is your chance to clean around the base. See those flat head plastic bolt heads? The tightening nuts are not visible from the front. They are reached by going under and then around the back.
    Guru:
  • 1,833 Answers
Yourtoilet seat is typically linked to the toilet with two plastic bolts and twonuts below. In the front of the cover, take a small screw driver and find alittle notch made to allow you to pry up the cover. Pry both of them up. Centerthe toilet seat on the toilet. Look closely at the plastic bolt head and decidewhich screw driver would fit. Use a large screw driver, otherwise the bolt willnot turn or it will slip. Turn the screw driver clockwise as pictured fromabove. There usually is a nut with a wing attached to prevent the nut from turning,so it should tighten. If the bolt keeps turning without tightening up, placethe small pair of pliers underneath, where you feel the nut and lock onto theend. Once you have turned the bolt several times, the wing on the nut willprevent it from turning anymore so keep screwing until it is tight. Push downthe covers and they should click closed. If you need some tools, then youcan shop it from http://www.amazon.com/Ginsey-85243-Toilet-Seat-Tightening/dp/B000CD1BOY.Hope this will help you.
Posted on May 28, 2011
  • 43,501 Answers
To tighten... you need to pop the caps open on the top of the bolts....to do that you often need a shape knife to slide in the seam and then pop the cap open...
Then a large screw driver can be used to tighten the bolts down... the nuts under neath are made so the should not turn when tightening and so that you do not need to get under there and hold them...
heatman101
Posted on May 29, 2011
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
I have a bathstore euro mono soft close seat. The hinge has come loose one side and needs to retightened. However, I cannot remove the seat from the hinge as the release button will not release the hi
Try using a knife to slide in the under-part of the release button and pop it off. If that doesn't work, you might have to brake it.
Oct 10, 2014 | Home
Why does my kohler quiet seat not soft close anymore
The cams are worn out inside of seat or it may be to lose you have to tighten up the seat if there is any adjustments if not it is worn out replace toilet seat.
Jul 01, 2014 | Kohler K-4748-47 Almond Saile Quiet Close...
One side of the toilet seat has come loose and can be partially lifted
It'll take getting down on your hands and knees in front of a toilet, but oh well. :-) Look beneath the side that is loose. There will be a threaded plastic bolt coming down from the top of the toilet to below where you are looking. On this threaded bolt there is a nut that needs to be tightened. Reach up and tighten it as tight as you can with your fingers. To make it even tighter, use a pair of pliers... then just snug it firmly. For ease in getting it off another time (e.g. should you want to replace the seat cover), I suggest first taking the nut OFF. Then take plumbers silicone tape (found in the plumbing section at any hardware store; it looks like white thin, thin tape) and wrap the bolt with it. Note: you need to take pull the bolt out completely to do this. After wrapping it with silicone tape, insert it back into the hole, and then twist the nut back on; snugging-up with a pair of pliers. This will keep the nut from working itself off, and will make the nut come off easy should you ever desire. Good luck.... :-)
Feb 27, 2011 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a euro mono back to wall toilet and teh toilet seat has come loose. I have detached the seatgfrom its fixings but cannot see how to ighten the fixing as the screw is not visible nor accessible
I know its a long time since this question was posted but I had the same issue and have just fixed it. Remove the toilet seat by pushing in each of the two release buttons on the hinges, then lift. Where the hinges located are two circlular receivers, both have a metal cap that can be removed using a small flat head screwdriver or similar. This reveals a large cross-head bolt head on each which you can tighten. I suggest nipping them up not overtightening just in case you damage the bowl. At least once you know where they are you can re-tighten another day! Then reassemble (remembering to put the caps back on first)... I hope this helps someone - I spent ages looking for the answer on the internet only to find it all out myself. Good luck...
Oct 09, 2010 | Eljer & Elongated Toilet Bowl
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 | Home
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Home Logo
380 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
