Hi. How do I remove the hard drive from my Advent Sienna 710 in order to replace it please? Cannot work out how to disconnect the drive from the sata II connectors as it seems quite stiff and i don't want to break it. thanks
SOURCE: Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Posted on Oct 16, 2008
Teis
  • 340 Answers
SOURCE: Need to know If I can use this hard drive in this laptop?
Hi again,
here is the awser to all you problems :-)
Get thise drivers:
http://www.softpedia.com/get/System/OS-Enhancements/nLite.shtml
download the drivers and unzip them (in case they come archived) in a desired location. Then download and install the Nlite application. When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
regards
/Teis
Posted on Nov 30, 2008
shishirgarde
  • 114 Answers
SOURCE: Compaq 6720 Hard Disk replacement
I agree, take a Seagate 500 GB 7200 RPM drive for laptops. The standards for the connections are same. So that would not be a problem. Make sure its for laptop and not the desktop one.
Posted on May 14, 2009
nyilasrobert
  • 627 Answers
SOURCE: SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Posted on Oct 22, 2009
Muzzi_123
  • 749 Answers
SOURCE: Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Posted on Nov 14, 2009
Testimonial: "Thank you for the advice!"
When I power on my Advent Tacto the Advent logo comes up and then just sits there. I have tried break on power up but that makes no difference.
Removing the hard drive will not boot to the BIOS. Try pressing F2 when your laptop is booting. Change the boot order to your hard drive.
Sep 18, 2016 | Advent Computers & Internet
How do i do an idle relearn on a 04 toy sienna
make sure you have no vacuum leak.
then disconnect the battery for 5 minutes then drive it normally with ac on
Aug 25, 2015 | 2004 Toyota Sienna
I need to replace the optical drive in a compaq presario c300nr laptop. How do I get to the drive?
Hi.
The hard drive cover is located at the base of the computer. To replace the hard drive:
1. Prepare the computer for disassembly, turn it off, disconnect power adapter and remove main battery.
2. Loosen the two Phillips PM2.5×5.0 captive screws that secure the hard drive cover to the computer.(see pic.1)
3. Lift the rear edge of the hard drive cover , and then swing it up and forward and remove it.
4. Slide the hard drive to the right, and then lift the hard drive from the hard drive bay.(pic 2)
5. Do operations in reverse order to install the new hard drive.
Pic1:
Pic 2
Regards.
Ginko.
Nov 17, 2010 | Computers & Internet
Keep getting a read disk error occured on startup and it says press ctrl alt del to restart but the same thing happens again.
Try re-seating your hard drive, removing and putting back in again. Make sure that your hard drive is the first boot in the order from the BIOS.
Oct 11, 2010 | Advent 4211c Notebook
Remove hard drive on advent 7017 and replace with new
I have provided a link to Cnet website to watch a detailed video on how to upgrade a hard drive.
here is the link:
http://reviews.cnet.com/4351-13747_7-6659221.html?tag=bestbuy
please rate this solution.
Dec 09, 2009 | Advent Netbook
Advent 7094swf turned off and never turn on again
i would say the hard drive needs replacing
Oct 15, 2009 | Advent Netbook
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Replacing RH Side view mirror on a 2006 Toyota Sienna
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Jul 29, 2008 | 2006 Toyota Sienna
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
