Question about Roper RAS8445KQ Top Load Washer
Machine will not empty water - Roper RAS8445KQ Top Load Washer
  • Roper Master
  • 8,220 Answers
Must be something in the pump. To verify simply lay the hose on drain hose down to floor level over a bucket. If no water comes out then your pump is blocked. In order to inspect for objects in the pump you must remove the cabinet to access the innards on this machine. Do not work from behind this machine. It is designed to be fixed in place. Flip up the controls and remove the cabinet. Get a pail to catch the water and remove the hoses to access the inside of the pump.
Video :sock in pump
Video: How to get inside machine
How it works
Repair photos and videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 28, 2011
  • Dan Webster
    Dan Webster May 28, 2011
    You never mentioned it would not spin either. You must think I am an idiot. The lid switch on your model will allow wash mode but not spin mode. You my friend have a broken lid switch if that pump is ok. The lid swich has two live wires and a green ground wire. Jump them 2 live wires and bypass the switch and she if she pump out Mon Ami.
How do I get water out of the inner tank of my B60 Keurig?
Turn off and unplug the Keurig brewer. Remove the water reservoir from the machine, empty it into the sink and place aside.
Move the machine to the side of the sink with the back hanging over the sink. Locate the drain cap on the back of the machine, and remove the drain cap.
Empty the water into the sink. Do not tilt the machine more than 90 degrees while emptying to make sure all water drains. Replace the drain cap. Place the machine back on your counter or in storage if you do not plan to use it.
Oct 08, 2014 | Keurig B60 Coffee Maker
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
Will not empty water
sounds like ur pump is getting weak and going out it will have to be replaced
Feb 25, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
My machine emptys the water but it does not turn
If the machine gets water but does not turn, then check lid switch, motor, and control board.
If no water is getting inside the machine, check inlet valve, water level switch and control board.
Jul 31, 2009 | Kenmore Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Pump not emptying on WMA74
behind the machine
remove the lower rear cover and the pump is in the corner.
empty water by putting the drain hose lower than the machine into a basin to syphon it.
Jan 27, 2009 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
