Question about Homelite Garden
GAS OIL MIX FOR HOMELITE UT20760 WEEDEATER - Homelite Garden
4 Suggested Answers
  • 107 Answers
SOURCE: oil to gas ratio
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Posted on Apr 20, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
  • 3074 Answers
SOURCE: model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
Posted on May 30, 2011
Need gas and oil mixture for 25 cc ut 08083 blower
Two-cycle engines use a mixture of oil and fuel to power and lubricate the engine. Homelite blower engines use a ratio of 50 parts gasoline to 1 part two-cycle engine oil. Two-cycle engine oil is commonly sold in 2.6-ounce containers; add it to 1 gallon of gas to achieve the 50:1 ratio. Two-cycle engine oil for outboard motors is not compatible with Homelite blowers.Use premium fuel,the blower,weedeater,etc. will last much longer!
Oct 31, 2015 | Garden
I put seafoam in my weedeater with on mixture of gas and oil and it runs better why
It can get its air easier. When using too thick an oil in the filter, sometimes the carby cant breathe properly and it will cause the motor to stall.
Aug 13, 2014 | Homelite Garden
I need to know the proper gas/oil mixture.
Hello. 40 to 1,or 8oz 2 cycle oil to 2.5 gallon of gas, or 3.2oz of oil to 1 gallon of gas. Joe
Jun 05, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Gas/oil mix
Most trimmers are using a 50:1 mix. 2.6oz/gal or 6.4oz/2.5gal. A 4oz/Gal is a 32:1 mix which way too oily and you will have problems of excessive smoke, oil leaking out muffler, carbon buildup causing sticking piston ring or a clogged spark arrestor.
Aug 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Oil to gas ratio
2.5 oz per gallon
Apr 20, 2009 | Garden
Garden Logo
158 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
