Question about Jacuzzi Ciprea Whirlpool Tub 9170
All of the plastic parts have turned yellow including the jets and their housings
The plastic on/off panel that one presses (part of the plastic yellow top assembly of this model) is broken ... machine itself worx.
I can only suggest that you ,first post what your working on. Then post it to the right category. Even though car mechanics work on many different motors and such. I don't remember any black button on a yellow housing. Maybe John Deer tractors?
Apr 26, 2015 | Cars & Trucks
What gearbox oil do I use formy 115 marener
Gear lube part # 92-858064Q01 is (32 fl oz) plastic bottle Quicksilver Branded, (Try Rechecking your wal-mart for Quicksilver part number 92-858064Q01). Or if you want a lot more oil, there is Part # 92-858065Q01 is 9.46 L (2.5 US gal) plastic bottle Quicksilver Branded.This SAE 90 gear lube features improved emulsifiers to help protect gears should water enter the gear housing and tackifiers to improve oil film adhesion to gears and internal components. There are extra additives to protect gears from metal to metal contact and excessive wear. Quicksilver High Performance Gear Lube is recommended for use in
outboards, Jet Pumps and Sport Jets above 75HP and for all sterndrives
Feb 04, 2015 | Cars & Trucks
White microwave keypad has turned yellow
The plastic will degrade over time, especially in the presence of heat or some chemicals, including cigarette smoke.
Jan 06, 2014 | Kenmore Microwave Ovens
My flo-Master XP2 06620397-2 has large leak when the jets are turned on. Do I need a new one or can the leak be repaired?
sounds like you need a new seal kit if it is leaking between the plastic pump housing and the motor. this seal kit is a model PS-200 and will run you about $30
US Parts Center
Aug 23, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Completed all these things; including the carb gaskets replaced and re-adjusted. The mower just will not start, with fresh gas, new air filter, and new spark plug - still no start. I do have a strong spark...
Hi imagditch...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
May 30, 2011 | Toro Garden
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Need replacement parts for a MAAX WESTCO INC A159869 8Z31 Jet Bath Tub Would like to replace the white plastic parts in side the tub with chrome as they have turned yellow
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
Aug 11, 2010 | Home
Jet bore threads not holding properly,side covers,breaking system
The jet bores are supposed to have a plastic liner near the outside of the bores that grips the jet screws to hold adjustment. You could try inserting a piece or two of thin plastic fishing leader, then inserting the jet screw. Don't insert so much leader that the material gets into the pointed end of the screw area as it will plug the jet. Any other threads that are not holding after being properly tightened can be be restrained by applying 'Loc Tite' thread locker fluid (from an auto parts house) to the threads before putting things together. Does the machine seem to have excessive vibration? Investigate the problem if it does. Hope this helps!
Apr 26, 2010 | Husqvarna Chain Saw 20" Bar
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 | Home
Jacuzzi Ciprea Whirlpool Tub 9170 Logo
1,081 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
