Question about Whirlpool Washing Machines
How to change a timmer on a whirlpool washer - Whirlpool Washing Machines
    Problem Solver:
  • 6 Answers
UnPlug. Most timer access thru Top Back Panel. Most all timers Have Color coded wires and Unplug with Spadelugs. Make a Diagram Sketch. I Always Tape # on them or some Timer assemblies Have a Master Coded Plug. Just Unplug and Plug new one in. Appliance Places are Helpful, Useful. Will Sell You Parts & Give You Tips. Have Make, Model. Call or stop by. You're Saving the Labor. Make sure the timer is Bad. Testing and Troubleshooting with a Little Knowledge will get Your Job Done. A Few will Require Tieing in wires with **** Splices.
Posted on Aug 16, 2008
My whrilpoo cabriol up right washer will not drain an spin
you have a bad timmer
you can order a new timmer
and install it cheap
or call a repair man
Nov 14, 2016 | Washing Machines
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
Will not spin in spin cycle. just a loud noise coming from the machine
the timer may need to be replaced are all the other cycles working except for spin? if so then the timmer needs to be replaced call a applance part store give them the make,model # and serial # its easy to replace timer.
Dec 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool duet washer has stopped mid cycle and the time display is flashing --- the dispay panel is frozen and will not respond to any of the control buttons including end of cycle,control on, hold to...
Sounds like the timmer in the control module has frozen and will not advance. It's one module for the whole display. I sometimes tap the module with a plastic screwdriver witch may releace it but it will do it again. I sorry to say but it's time for a repair man. I do't have the writing space to tell the procedure (if it is the problem) - Sorry, not good news
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
Stuck on rinse cycle
Your water valve is bad or the cold side of the valve is stopped up with sediment. Clean the water valve inlets. If that does not correct the problem, replace the water valve.
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't drain
while machine is on move the timer little if that start working it is the timer. and that can be replace very eaisyle
Feb 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Mar 30, 2007 | Frigidaire GLWS1233A Top Load Washer
Whirlpool Ultimate Care II GSQ9669LGO
Sounds like you may need to replace the timmer
Jun 06, 2006 | Whirlpool Ultimate Care II GSQ9669L Top...
Washing Machines Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
