Question about Ovens
I AM RECEIVING EO SA6 ON MY KENMORE OVEN - Ovens
  • tracydrag166 May 28, 2011
    when i hold in the start pad it turns the PF SA6 code to a E6 SA6 error and then if i hold in the clock pad EO SA6. Yesterday when i held in the clock tab i had E6 SA6 so i unplugged it overnight, plugged it back in today and now receiving the EO SA6.
  • 4,323 Answers
Hi
The error code is SAB not 5a6 which means that the oven is in Sabbath mode; you can reset the controls by pressing the CLOCK button and hold it for 15 seconds. If the issue returns with the error code EO then it means the control board assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 28, 2011
  • Daniel Scott
    Daniel Scott May 28, 2011
    The control board/keypad is bad and should be replaced.
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
Hello. I have a Kenmore Ultra Bake, with push button control. After wiping down the panel it went crazy. The panel is now showing EO F2 and continuously beeping. I can use the stovetop, but can't turn...
Hi
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Kenmore Ovens
Kenmore Mod.# 75824 I have a Fault Code EO-F3- the oven does not come on. No time display. I've reset the breaker and pushed the cancel/off button no help. This occured during a power outage.
Shorted sensor. Unplug the sensor and check it between each prong and the frame. If you get continuity you have a bad sensor. If the sensor is good, the wiring or the oven control is bad. The oven control has got to have a good sensor so it can know the temp inside the oven.
Jul 12, 2010 | Kenmore Ovens
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
Blinking EO and F2
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
EO -F2- Error?
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric oven
Shorted keypad Replace Electronic Range Control/Clock (erc)
Jan 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
