Question about Keurig Platinum B70 Coffee Maker
Pressed the brewing button and machine says brewing but nothing come out
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 05, 2011
SOURCE: Machine shuts down when brew button is pressed.
I pulled the plug cleaned the machine thoroughly and it is back to normal. Right now i'm in contact with Keurig for a replacement part that is broken.
Posted on Aug 01, 2009
SOURCE: The machine says REady To Brew- the lights flash
Mine does this all the time. When it does, I tap the top of the machine and the coffee comes out. I don't know if it will work for you, but it works every time for me. It's like there's a small clog or something.
Posted on Nov 17, 2009
  • 25 Answers
SOURCE: Machine Stopped Working
A couple of things: the buttons themselves are bad or its the circuit board.
Posted on May 14, 2009
SOURCE: Platinum B70 sometimes won't brew
Not that this is ANY help, but the same thing is happening to me right now as well with the B60. I am also awaiting my hopefully helpful reply. Sigh
Posted on Jun 11, 2010
  • 81 Answers
SOURCE: ! light flashing... machine won't
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Posted on Oct 11, 2010
Mr coffee keurig problems
You have to select a serving size before pressing the brew now button.
Jan 06, 2014 | Coffee Makers & Espresso Machines
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
Will not brew . says ready to brew but when I press brew button nothing happens
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101]][[]
Aug 19, 2011 | Keurig Ultra In Home Single Cup Brewer...
I also have the same problem. Is there a pattern here?
Jun 11, 2010 | Keurig Platinum B70 Coffee Maker
The machine says REady To Brew- the lights flash and i press the button to brew. It says "brewing" but nothing ever comes out and then it goes back to "Ready to Brew".
Nov 01, 2009 | Keurig Special Edition B60 Coffee Maker
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Keurig Platinum B70 Coffee Maker Logo
107 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
